[rebel-builders] Brake line routing on SR
Post by Mike Kimball » Sun Feb 19, 2012 2:12 pm
Some of us tee off the line and then go to both calipers from the tee.
Seems like doing it as you describe should be OK.
jtpackard@usfamily.net
Sent: Saturday, September 23, 2006 6:43 AM
Subject: [rebel-builders] Brake line routing on SR
Does anyone know if there is a reason to run my brake line into the top of
the forward caliper rather than into the top of the aft caliper? I noticed
a photo of a Moose with the line coming down the backside of the gear leg
and then cross over to the forward caliper. I'd prefer to go into the rear
one first, out the bottom and then over to the forward one.
Thanks for any comments.
Tom Packard
SR 043
--- http://USFamily.Net/dialup.html - $8.25/mo! --
http://www.usfamily.net/dsl.html - $19.99/mo! ---
