[rebel-builders] OIL GAGES
Post by Drew Dalgleish » Sun Feb 19, 2012 2:04 pm
At 08:14 AM 8/14/2006 -0400, you wrote:
hi all
i have scott oil temp and pressure gages
can someone tell me when temp probes goes into engine do you use teflon tape
or anything on threads ?
also with the murphy firewall forward kit there seems to be a ton of small
brass fittings for oil pressure line, has anyone used all these fittings,
what are they all for ?? also where do you get pressure tap from on the
engine ?? pics of test run of my engine from leavens shows line coming off
front of engine ??
mike#007
I don't like teflon tape locktite 582 thread sealant works much better.
Temp probe goes under the filter somewhere and pressure comes off the right
rear corner. When I have questions like this I go to the airport and see
how cessna and piper do it.
Post by Mike Kimball » Sun Feb 19, 2012 2:04 pm
I am also not a fan of Teflon tape. I like JOMAR "Gimme the Green Stuff"
pipe thread sealant.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jones,
Michael
Sent: Monday, August 14, 2006 4:15 AM
To: Rebel-Builders (E-mail)
Subject: [rebel-builders] OIL GAGES
hi all
front of engine ??
mike#007
