How do you fit the 90 degree bracket between the bottom of fus 27 and the
door post? The bottom leg of the bracket will have to do a zig-zag or
something to fit over the rivet heads that hold the fus 2. Should I drill
out 3 of those 3/16 rivets and then re-rivet with the bracket there, or
extend the bracket to zig-zag and hit the door post below the fus 2? Not a
very clear description, but those of you who have been there will get it I'm
sure. If I attach it using the existing 3/16 hole in the fus 2 per the
manual, then do I just use that one hole or drill 2 more? This would seem to
put many holes in a small area of the fus 2/door post intersection as the
3/16 holes are 3 abreast in this area. (sort of a triple nipple, one could
say)
