spinner
Murray and Carol Cherkas
spinner
Post by Murray and Carol Cherkas » Sat Feb 18, 2012 2:12 am
Hello ALL
I need a 10" or 11" spinner with back plate for an 0-320, Sensenich prop.
Just asking incase anyone has changed props and has spare parts.
Murray
cherkas@shaw.ca
Spinner
Post by Ralph Baker » Sat Feb 18, 2012 12:27 pm
Clay,
Van's also has a 13" fiberglas spinner if Wayne can't supply. The
fiberglas units are much easier to fit as you can see through them to
correct drill locations.
Elite 624E
Clay Smith
Spinner
Post by Clay Smith » Sat Feb 18, 2012 12:27 pm
Thanks Ralph, I'll keep that in mind.
Sent: Wednesday, September 08, 2004 9:55 PM
Subject: Spinner
Clay,
Elite 624E
indabush
Spinner
Post by indabush » Sun Feb 19, 2012 2:00 pm
Anybody out there got some "spinner" info? I have the speed cowl (requires
13" diameter spinner), and will be getting a Prince prop (3.125" thick
with 3/8" crush plate).
Does the MAM spinner work?
Other sources? As far as I know UHS does not have a suitable model.
Mike.
_____________________________
Mike Ash, Rebel 305R
spinner
Post by Ralph Baker » Sun Feb 19, 2012 2:00 pm
Van's has a 13" spinner with plates for the Sensenich fixed pitch prop. I went that route after reading the MAM instructions several times and not wanting to do all the work involved. The fiberglass is impeccable and easy to see through it to drill. The plates are completed.
Rallph Baker
indabush
spinner
Thanks for he advice Rallph and Al. Vans says their FP-13 SEN spinner has
a design distance between the two bulkheads of 3.75 inches. My Prince
prop, with a crush plate, is 3.5 inches. and therefore a 1/4" spacer would
be required, and I will need new prop bolts. Having never done a spinner
before, I guess this is OK. I have been trying to get the design specs
from MAM for their spinner without any luck.. You know how that goes.
Michael Ash, 305R
You wrote:
Date: Sat, 29 Jul 2006 17:14:47 -0400
To: rebel-builders
Subject: spinner
Rallph Baker
Date: Sun, 30 Jul 2006 17:32:10 -0400
To: rebel-builders
Subject: RE: [rebel-builders] Spinner
Try the Vans 13" spinner. Works beautifully with the speed cowl.
Al
