[rebel-builders] wheel alignment
James Vandolder
Post by James Vandolder » Sun Feb 19, 2012 10:39 am
The Murphy ones are not drilled. Although we haven't
gotten there yet, the EAA group on the field has gone
through installing the Murphy wedges with good
success!
James - reb 493
--- Ralph Baker <rebaker@sc.rr.com> wrote:
The new Vans catalog also lists whel alignment
wedges in 1/2 and 1 degree adjustment. Have not yet
confirmed that the bolt patterns are same as MAM.
Rallph Baker
List archives located at:
https://www.dcsol.com/login
Do You Yahoo!?
http://mail.yahoo.com
[rebel-builders] Wheel alignment
Post by Ken » Sun Feb 19, 2012 10:59 am
Good article in Kitplanes this month on alignment and shimmy.
Quick summary said set zero with the tail up in flying attitude and
avoid toe in IIRC. Mine is different in 3 point versus tail up attitude.
Mike Kimball wrote:
I went through the archives and discovered the toe out versus toe in
controversy and also the frequent comment about setting them straight ahead
and leave it at that. I measured the distance between my tires at the front
and at the back and the front measurement is one centimeter less than the
back. So I have a slight toe in. I'm inclined to just leave it that way.
I figure it would only be bad if one was straight and the other accounted
for the entire toe in. Any tips for making sure that isn't the case?
044SR
James Vandolder
Post by James Vandolder » Sun Feb 19, 2012 10:59 am
Certified aircraft sometimes suggest using a long
straight piece of wood across the front of both tires.
Take a carpenters square along the wood, and check if
it touchs the brake disc at both the front and back.
Good luck!
out versus toe in
044SR
Do You Yahoo!?
