unattended. To take the load off the stick I installed a trim tab on the
right flaperon. Actually a piece of my first moulded windshield that had the
proper curve in it and didn't have the sharp edge to slice someones head
open. Works like a charm.
With ailerons you can cheat on the adjustment a bit to help keep the wings
level. With the full flaperons U can adjust the push pulls to your hearts
content...it will do nothing but move the stick off center. The trim tab (or
wing being moved up/down) will help you out.
wayne
Sent: Sunday, June 25, 2006 10:12 PM
Subject: Re: [rebel-builders] CHTs and EGT
toHi Clay
Got the bugs out of my tailwheel. Put an eye bolt upside down thru the
cable clevis and ran my chains back from there which gave me more travel
170kick out the steering lock. Have 6 hrs on now with 320 cht and 1350 egt
is.oil temps with 80 mineral oil. Air temps not really bad now 20-25 cel. Had
trouble with the flaperons not extending evenly but know what my problem
LostFlys level and hands off with a little reflex but as soon as u go past 0
flap, it loads up the control stick with left wing down. ( Wayne if ur
reading this, please join in). Have 20* of flaperon which slows nicely.
aAlvins message and was going to respond to it. Have the Prince prop also
and will be having a few words with Lonnie. Have the 74/45 p tip and have
the105 mph cruise at 2400 but will over rev if i get above 65 in the climb.
Need more pitch. He suggests the 74/45 for the 150 hp and the 74/47 for
and160. Think the 47 would fine for the 150 . Alvin is obviously too fine
may benifet from what i have. Can't believe the take off with 0 flap and
the fine pitch prop.
Take care
Steve W #637R
