terry
done all this but iron i used only went up to 300, so need to find one that
goes to 350, don't want to keep buying and returning irons, stores don't
like that,,
nice number of your rebel i see, 666, will it be painted red by chance ??
mike
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of
tlmcclary@juno.com
Sent: Thursday, June 29, 2006 10:59 AM
To:
rebel-builders@dcsol.com
Subject: Re: [rebel-builders] fabric iron
Mike,
When Millers (
http://www.aircrafttechsupport.com/) give the class at
Oshkosh they tell you to go to your local discount store and buy an
iron with the variable temperature control. (And if I remember
correctly, they said the cheaper irons were as good as the expensive
ones.)
To calibrate the iron you put heat sink compound on a paper towel (the
compound is silicon based so they don't want you to contaminate the
face of the iron and transfer the silicon to the fabric) and then
stick a thermometer in the heat sink compound. They recommended
marking the variable dial with your different temperatures as a
starting point for next usage but checking the temperature each time
before you start the shrinking process.
Suggest you call Millers if you need any tips. They always seemed
very helpful at the shows.
Terry
R666
-- "Jones, Michael" <
Michael.Jones@snclavalin.com> wrote:
hi all
can anyone suggest an iron to use for fabric, according to poly fibre
it
should go up to 350 deg but none of the irons i have look at give
temps so
how do you pick one ??
mike#007
List archives located at:
https://www.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
