[rebel-builders] Re: Elite # 640E
N.Smith
Post by N.Smith » Sun Feb 19, 2012 10:48 am
Hi Hans
The extra float bulkheads are ahead of the normal fuselage bulkhead. Your
floor pan should pick up the fuselage bulkhead at the rear edge, with the
float extra bulkhead being just ahead of it.
The side skins should meet the rear of the cabin area squarely, so that just
leaves the roof panel that should overlap the tailcone skin and pick up the
upper flange of the normal fuselage bulkhead.
If that is not what you have, can you email me direct (NOT via the list as
it will not do it) a few photo's of what you have ?
Nigel
745E
admin@airnig.co.uk
Hans Kuck
Sent: 21 May 2006 03:50
Subject: [rebel-builders] Re: Elite # 640E
Can anyone tell me please what I am doing wrong.
I am trying to mate the Cabin to the Tail Cone.
I get the sides nicely together without Oil Canning, however the Cabin
Roof is about 3/16 to short.
Or I can get the roof nicely lined up and the bottom of the cabin and
the Tail Cone
but not the top part of the sides. I had all three together about
three weeks ago .
Since then I in stalled spacers (1/4 ")between the bulkheads that holds
the Float attachment to stiffen up the sloppy bulkhead.
Does anyone have the the precise measurements between bulkheads?
Any help would be much appreciated!!!
Hans
On 20-May-06, at 4:22 PM, David L. Tuck wrote:
Can anyone tell me why ? they ( mam ) is using such a large tail
spring? I
don't see any reason that a spring off a luscombe or other small
taildragger
wouldn't work.
Are there any other ideas out there ? I saw the trailer spring in the
archives, and that seems to be the only tail spring system that I
saw in
there.
I think that is whats causing all the cracking in the fus 30 ?
Dave T/ 009
Kind regards
Western Transportation
c/o Hans Kuck
P.O. Box 36023, 10991 # 1 Road
Richmond B.C. V7E 3E6
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
mailto:hansk3d@dccnet.com
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 10:48 am
Not that it will help your problem, but the extra half bulkhead for the
float attach fittings (which, as Nigel says, goes in front of the main
bulkhead on the Elite, is normally just pulled in to join the main
builkhead at the top, with no spacer. That does result in two
non-parallel rows of rivets, but that's the way it's supposed to be.
I'm not really sure what your problem is, but the cabin and tailcone
bulkheads should be parallel. I'll be at the hangar todat, and will
measure from the rear cabin bulkhead to the front tailcone bulkhead, if
that will help.
Al Hepburn
Hans Kuck
Post by Hans Kuck » Sun Feb 19, 2012 10:48 am
Hi Nigel, I'll send you some pictures
thanks
hans
On 22-May-06, at 2:26 AM, N.Smith wrote:
Hi Hans
bulkhead. Your
with the
that just
pick up the
list as
Nigel
745E
admin@airnig.co.uk
Hans Kuck
the Tail Cone
three weeks ago .
holds
Hans
spring? I
taildragger
wouldn't work.
saw in
there.
Dave T/ 009
Kind regards
c/o Hans Kuck
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
Kind regards
c/o Hans Kuck
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
Hans Kuck
Thanks Alan, anything will help
thanks
Hans
640E
bulkhead, if
that will help.
Al Hepburn
Kind regards
c/o Hans Kuck
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 10:48 am
Hans,
I'm not sure what your problem is either. I mated mine about a year ago and
don't have the memory for details like Al has. If you want a specific
measurement or from what point let me know where. Or if you want to share a
picture showing something you can send it to mbetti@up.net . My interior is
completed but just in paint. I won't be able to measure anything from the
corner warps or the floor down since they are covering up the bulkheads now.
Mike Betti
771E
Sent: Saturday, May 20, 2006 9:49 PM
the Tail Cone
three weeks ago .
Hans
spring? I
taildragger
wouldn't work.
saw in
there.
Dave T/ 009
Kind regards
c/o Hans Kuck
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
Hans Kuck
Post by Hans Kuck » Sun Feb 19, 2012 10:52 am
Thanks Mike
thanks I will get back to you
thanks for your help
Hans 640E
On 23-May-06, at 7:11 PM, Mike Betti wrote:
Hans,
ago and
share a
interior is
from the
bulkheads now.
Mike Betti
771E
Cabin
the Tail Cone
three weeks ago .
holds
Hans
spring? I
taildragger
wouldn't work.
saw in
there.
Dave T/ 009
Kind regards
c/o Hans Kuck
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
Kind regards
c/o Hans Kuck
Canada
Ph. 604 244 0480
Fx. 604 244 0482
Cl. 778 773 8364
