[rebel-builders] Finishing the aileron torque tube
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 10:48 am
Hi Mike,,,, GO to Chapter 12 Controls,, Step 80 page 29 is where you will
find the information in the MANUAL.. Dale SR-033
Post by Mike Kimball » Sun Feb 19, 2012 10:48 am
There it is! Thanks Dale.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Dale
Fultz
Sent: Monday, May 22, 2006 4:52 AM
Subject: Re: [rebel-builders] Finishing the aileron torque tube
Reed Britt Civ 309 MXSG/M
Post by Reed Britt Civ 309 MXSG/M » Sun Feb 19, 2012 10:52 am
Mike - Did you catch the reference to putting safety wire on the outboard
end of the Aileron Torque tube bolt(pivot point)? - I had one wing finished
that I have to go back and do but I had the other one still opened up when
Scott Aldrich gave me the heads up and it was easy to do.
Britt A. Reed
309th MXSS/MDEA
5832 H Ave. Bldg 843
Hill AFB UT 84056
(801) 775 4471
Kimball
Sent: Sunday, May 21, 2006 9:30 PM
To: Rebel Builder's List
Subject: [rebel-builders] Finishing the aileron torque tube
I've got the fuselage on its gear and the wings ready to mount and I notice
that I still haven't finished off the aileron torque tubes at the wing root
end. I scoured the manual and, no surprise, I cannot find anything that
tells me what I'm supposed to attach to that end. I found some El-31
fittings to go inside the 2-inch tube, and the little rings to go outside
the tube for the rivets, and some straight horns that are 4 inches from
pivot point to attach point. I'm guessing these are the parts to use. But
I guess I'll be on my own for figuring out what direction the horn should be
pointing when I rivet it on. Any tips? Are these the right parts?
044SR
