[rebel-builders] Scott 3200 tailwheel
Post by Drew Dalgleish » Sun Feb 19, 2012 1:47 pm
At 11:00 PM 5/16/2006 +1000, you wrote:
G'day
I have just fitted a Scott 3200 tailwheel to my 912 Rebel and I am pleased
to say that the difference is amazing.
The ride and the general handling is greatly improved and even the oil
canning noises that she made is reduced.
I have noticed that I need a little more nose down trim so I guess the extra
3 pounds at the back have made a difference, but things work out OK with the
weight and balance.
Anyone want to buy a used rebel tailwheel? Cheap!
regards
Ian
That's good news Ian. What tires are you using on your main wheels and do
you notice a different attitude on the ground? My tailwheel is already
showing lots of wear on the tire and in the swivel.
Ian Donaldson
Post by Ian Donaldson » Sun Feb 19, 2012 1:47 pm
G'day Drew
I am using the standard Murphy issue tyres (6" I think)
The attitude on the ground is different, but gives you a better look over
the nose when taxying. I took a little time to adjust to the new attitude
when I am landing but that is no big deal.
I can recommend a change to a Scott!
regards
Ian
: That's good news Ian. What tires are you using on your main wheels and do
: you notice a different attitude on the ground? My tailwheel is already
: showing lots of wear on the tire and in the swivel.
: >I have just fitted a Scott 3200 tailwheel to my 912 Rebel and I am
pleased
: >to say that the difference is amazing.
: >The ride and the general handling is greatly improved and even the oil
: >canning noises that she made is reduced.
: >I have noticed that I need a little more nose down trim so I guess the
extra
: >3 pounds at the back have made a difference, but things work out OK with
: >weight and balance.
: >Anyone want to buy a used rebel tailwheel? Cheap!
