that 0-320 160hp can use autogas with the stipulation
it is 91 octane or higher. Some 0-360's are also
included that have this stipulation.
Keith R661
--- bransom@dcsol.com wrote:
-----------------------------------------------------------------I haven't picked up the Kitplanes yet but...
150/160 isn't the issue per se with car or av gas.
The issue there is
compression. Higher compression increases tendency
to predetonate or
knock and higher octane helps avoid this. As long
as compression is not
raised above mid 8:1 I believe, high octane (91,92)
car gas should suffice
(this from a conversation I had once with Lycon.) I
believe the typical
160 "high compression" piston 0320s is higher than
9:1 -- I know it precludes
use of car gas anyway.
The issue of water (from ethanol) is a separate one.
Some believe it is
acceptable in Lycomings due to the carb intake
routing, not acceptable in
Continentals. I don't think anyone would argue
ethanol doesn't add at least
some risk for carb icing -- why the heck would there
be carb heat on a Lyc
designed for non-ethanol fuel in the first place.
But, I've heard plenty argue
that some ethanol is acceptable if carb heat
practices are ardently followed --
and depends on climate too --- but for what level
of ethanol I don't know.
It seems reasonable to me to weigh the up/down sides
of ethanol against the
longer term up/down sides of lead.
Gas additives (besides ethanol) is yet a third
issue.
Gotta go pick up that Kitplanes article!
-Ben
from it is that lead is notI read the fuel article in Kitplanes. What I gotethanol is definately badthe issue with airplane engines, but octane, andfreeze. It went on to say thatbecause it traps water in the fuel which canignition systems withwe could run on lower octane gas with improvedrelationship tie in? Is car gas onlyvariable timing.
How does the 150/160 hp, car gas/avgascaused by lower octaneapproved in 150 hp engines because detonation
car gasengines ok with car gas?is less damaging to those engines? Are any 160hpThanks
-----------------------------------------------------------------List archives located at:
https://www.dcsol.com/login
Do You Yahoo!?
http://mail.yahoo.com
