[rebel-builders] Trip West & East ---was 1800 amphibs
Post by Bob Patterson » Sun Feb 19, 2012 10:44 am
Hi Walter !
A few hangups at the moment, but the plan is to leave here July 7th,
arrive Chilliwack about July 15th, then head back here for July 21st,
to get to Oshkosh for the 22nd or 23rd ...
Will keep everyone updated as soon as we know for sure ... :-) :-)
Looks like that schedule will work well for you to fly back with us.
On Sunday 07 May 2006 07:43 pm, Walter Klatt wrote:
Yep, as far as I'm concerned. Don't think will make the 18th, as I won't be
leaving Nimpo until the morning of the 16th. Will meet up with Al P. that
evening or the next day, depending on the weather, and head east.
How about Bob P. and the Ramble? You guys still heading out west? Bruce G.
and I, and whoever else is along, want to spend the week after Arlington
flying around BC and to Nimpo Lake. There are a lot of great places here to
visit both on floats and wheels and would be happy to show people around.
G. O'Shea
Sent: May 7, 2006 12:30 PM
Subject: Re: [rebel-builders] 1800 amphibs
Great! Is the "big trip" still going ahead as expected with a July ~18th
arrival date?
Sent: Sunday, May 07, 2006 3:17 PM
Subject: RE: [rebel-builders] 1800 amphibs
Just got back again from my hangar, and I think the job is finished.
Managed
to get everything together again properly, and to my surprise no leaks.
Had
to get all the air out again and tested it best I can, but it looks good.
It was brutal, though, and sure don't want to have to do that again.
G. O'Shea
Sent: May 7, 2006 8:19 AM
Just think Walter...Bruce will get to nag you over the radio for 2500
miles
if it doesn't work! ;o)
Sent: Sunday, May 07, 2006 11:15 AM
Mine only has a single O-ring there, so I guess that explains it. Like
I've
said before, one of these winters, I want to take the floats right off
for
full inspection, but hopefully this fix will get me by for another
summer.
Bruce
Georgen
Sent: May 7, 2006 7:34 AM
Walter,
It's the front end cap that now have two small o rings (like the
piston) instead of one... if you buy the whole cap new. This is where
my cyl.
have
leaked as the rod moved in and out. I suspect this is why they changed
design. I reused the rear end cap o rings because I didn't have
replacements
but they worked fine with no leaks.
I suspect it might have been easier to just remove the whole wheel to
get
the cyl. and check the bearings/brakes and everything else, for piece
mind, while you have it apart.
I suggest checking the axles for rotation in the c clamp with a mark.
Both
my axles where rotating even with the bolts/nuts over torqued. I had to
sand
down the c clamp on a disc sander so it would grab the axle correctly.
Bruce G
noticed
off
as
eventually
while
must
be
still
hole
for
watching
for
guess
Bruce
that
c
mark
some
is
not
for
never
avoid
well
Bruce
it
apart
as
in
pour
give
be
out....then
it
wire
with
should
grips
down
problem?
Of
after
rods
O -ring
is
parts
polluting
found
rear
notice
really
undo
if
Behalf
Of
at
hold
When
pump
pressure
will
location)...it
valve
pump
you
check
line
Nancy?
how
it's
sun.
good
worry
minute
other
my
want
taxiing.
maintain
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
Post by Walter Klatt » Sun Feb 19, 2012 10:44 am
OK, keep us informed as we get closer. It would be good if you could make it
a few days earlier to spend some time here visiting some spots. Weren't you
going to get your amphibs fitted this year?
Patterson
Sent: May 7, 2006 3:58 PM
Subject: Re: [rebel-builders] Trip West & East ---was 1800 amphibs
Hi Walter !
be
G. O'Shea
arrival date?
Managed
Had
good.
G. O'Shea
miles
I've
for
summer.
Bruce
Georgen
Walter,
my cyl.
have
replacements
get
Both
sand
Bruce G
noticed
off
as
eventually
while
must
be
still
rod.
cap
hole
for
watching
for
guess
Bruce
that
off
c
mark
some
is
not
winter
for
never
avoid
well
Of
Bruce
it
apart
as
it
in
pour
give
be
out....then
it
wire
with
should
vice
grips
sliding
down
problem?
Behalf
Of
after
rods
O -ring
is
parts
polluting
found
rear
notice
that
really
undo
if
Behalf
Of
now
at
hold
dump
When
pump
pressure
building
pressure
will
location)...it
valve
pump
If
you
check
line
Nancy?
how
it's
sun.
good
wouldn't
worry
minute
other
my
want
taxiing.
maintain
PeoplePC Online
That WAS the plan ..... sigh ...
Might happen ....
If so, I'd like to come for Arlington. Will let you know when I do !
it a few days earlier to spend some time here visiting some spots. Weren't
you going to get your amphibs fitted this year?
Patterson
Hi Walter !
be
G. and I, and whoever else is along, want to spend the week after
Arlington flying around BC and to Nimpo Lake. There are a lot of great
places here
G. O'Shea
arrival date?
Managed
Had
good.
G. O'Shea
miles
I've
for
summer.
Bruce
have
replacements
get
Both
sand
noticed
off
as
eventually
while
must
still
rod.
cap
hole
for
watching
Bruce
that
off
mark
some
is
winter
for
never
avoid
well
Of
it
apart
as
it
in
pour
give
be
out....then
it
with
should
vice
sliding
down
problem?
Behalf
Of
after
rods
O -ring
parts
polluting
found
rear
notice
that
really
undo
if
Behalf
Of
now
at
hold
dump
pressure
building
pressure
will
location)...it
valve
pump
If
you
check
Nancy?
how
it's
sun.
good
wouldn't
worry
minute
other
my
want
taxiing.
maintain
PeoplePC Online
[/quote]
Bruce Georgen
Post by Bruce Georgen » Sun Feb 19, 2012 10:47 am
Bob P,
Looking forward to seeing you again with or without your amphibs. Don't forget your spare tubes! Well, you know what I mean. Thanks again!!!
Bruce G
Sent: May 8, 2006 7:11 AM
Might happen ....
Patterson
Hi Walter !
be
places here
G. O'Shea
arrival date?
Managed
Had
good.
miles
for
summer.
have
get
Both
off
must
still
rod.
cap
watching
that
off
is
winter
never
well
Of
apart
as
it
in
pour
give
out....then
with
should
vice
sliding
problem?
Behalf
Of
after
O -ring
parts
found
rear
that
if
Behalf
now
hold
dump
building
pressure
location)...it
pump
If
check
Nancy?
how
it's
sun.
good
wouldn't
worry
minute
other
my
want
taxiing.
maintain
PeoplePC Online
[/quote]
[/quote]
PeoplePC Online
