[rebel-builders] Moose: Elevator Tip Skin cracks
Post by Mike Kimball » Sun Feb 19, 2012 10:44 am
Good stuff Ted. Keep it comin'.
Waltman
Sent: Sunday, May 07, 2006 4:45 PM
Cc: murtech@murphyair.com
Subject: [rebel-builders] Moose: Elevator Tip Skin cracks
Guess I'm just lucky to find these things. Hopefully by documenting the
issues I find such will help others still in the build process or prompt
others that are now flying to double check their planes.
Last year I discovered small cracks in the underside of both elevator tip
skins (part # EL-313). I drilled relief holes and kept an eye on them. On
the left side, I had to drill a second set of holes later in the year.
Looking at the extent of the cracks, particularly on the left (pilot) side
it is evident that a major "redo" of this area is now in order. As such,
I've asked a few friends what techniques they might suggest....
[ Please see the rest of my comments and pictures here:
http://www.i1ci.com/Flying/Moose/Elevator/Elevator.html ]
Thank you for your input.
Ted Waltman
Moose N142SR
Nielsenbe
Post by Nielsenbe » Sun Feb 19, 2012 10:44 am
I know a great way to work on a fix.....complete tail kit available for
parts and it's in colorado already.
Brad
