Rebel Nut plates
apoulsen
Rebel Nut plates
Post by apoulsen » Sun Feb 19, 2012 10:43 am
Anyone have a source for the nut plates for the aileron hinges?
Allen Poulsen
786R
bransom
Rebel Nut plates
Post by bransom » Sun Feb 19, 2012 10:43 am
vansaircraft.com or aircraftspruce.com both work. I didn't bother with
floating nut plates but you will need single lug for these locations. I used
solid an3 flush rivets to tie the nutplates to flat stock first, and then these
are picked up with some of the other regular hinge plate 4010 rivets (pics at
http://mae.ucdavis.edu/ransom/Murphy/10.05). Not sure how typical this is,
but I wanted to do it in way that I could repeat later when I retrofit the right
wing. (didn't know about this tip when I did right wing)
-Ben
On 5/1/2006 2:44 PM, apoulsen@comcast.net wrote to rebel-builders:
Allen Poulsen
786R
bransom
Rebel Nut plates
meant to say .................. regular hinge plate 1410 rivets
-B
