[rebel-builders] Shop talk - washers
OK, Wayne, gotta ask this. Do you carry a magnifying glass with you all the
time in the shop? Yup, sad to say, but I guess 50% of the washers on mine
are all wrong...
G. O'Shea
Sent: Thursday, April 13, 2006 7:54 PM
Subject: [rebel-builders] Shop talk - washers
Realized while working away today I do something subconsciously (or possibly
automatically is a better word). Guess I've been doing it so long I dont'
give it a second thought anymore.
It may have been discussed here before, but you do realize there is a right
and a wrong way to install a washer...right? They are punched out of a
sheet....creating a sharp edge and a rounded edge. The rounded edge should
always go against the surface you are bolting together as the sharp edge
will cut into the alum and cause a stress point. Just thought I'd share that
tidbit of knowledge on a slow Thursday night.
are all wrong...
G. O'Shea
The rounded edge side has a different shine/look to it. Easy to detect once
you've been looking purposely. I started doing this years back after
disassembling airplanes and finding a nice round "cut me here" line the
diameter of the washers. This imbedded line is from the sharp edge of the
washer getting forced into the alum.
Sent: Friday, April 14, 2006 9:53 AM
Subject: RE: [rebel-builders] Shop talk - washers
theOK, Wayne, gotta ask this. Do you carry a magnifying glass with you all
Waynetime in the shop? Yup, sad to say, but I guess 50% of the washers on mine
are all wrong...
possiblyG. O'Shea
rightautomatically is a better word). Guess I've been doing it so long I dont'
thatand a wrong way to install a washer...right? They are punched out of a
OH NO now I gotta take my plane apart to check the washers and start all
over ;(
over ;(
Hello Wayne
So evident after we know it.... Thanks for the info....
A happy Easter to everyone of you and to your familly!
Jean
Rebel 747R
Sent: Friday, April 14, 2006 10:02 AM
Subject: Re: [rebel-builders] Shop talk - washers
Jean
Rebel 747R
once
theOK, Wayne, gotta ask this. Do you carry a magnifying glass with you allWaynetime in the shop? Yup, sad to say, but I guess 50% of the washers on mine
are all wrong...
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf OfpossiblyG. O'Shea
Realized while working away today I do something subconsciously (orrightautomatically is a better word). Guess I've been doing it so long I dont'
It may have been discussed here before, but you do realize there is athatand a wrong way to install a washer...right? They are punched out of a
should
will cut into the alum and cause a stress point. Just thought I'd sharetidbit of knowledge on a slow Thursday night.
On the worst offenders you can often also feel the sharp edge on one
side of the washer. Some don't have much edge but others do. I have also
found a few bolts with bumps or edges under the heads. They need a more
careful inspection to catch but you will notice the scored aluminum
after removing one of them...
are all wrong...
Somebody needs to post the washer info on a Van's site, it will send those
engineer types into a frenzy ... maybe that was the cause of some structural
failures ... Just joking, but now I'll not put one upside down washer on any
aircraft (or sawhorse) again!
On 4/14/2006 6:02 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> The rounded edge side has a different shine/look to it. Easy to detect once
-> you've been looking purposely. I started doing this years back after
-> disassembling airplanes and finding a nice round "cut me here" line the
-> diameter of the washers. This imbedded line is from the sharp edge of the
-> washer getting forced into the alum.
-> Wayne
-> From: "Walter Klatt" <Walter.Klatt@shaw.ca>
-> Sent: Friday, April 14, 2006 9:53 AM
-> Subject: RE: [rebel-builders] Shop talk - washers
-> > OK, Wayne, gotta ask this. Do you carry a magnifying glass with you all
-> the
-> > time in the shop? Yup, sad to say, but I guess 50% of the washers on
mine
-> > are all wrong...
-> > Walter
-> > From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of
-> Wayne
-> > G. O'Shea
-> > Sent: Thursday, April 13, 2006 7:54 PM
-> > To: Murphy Rebel Builders List
-> > Subject: [rebel-builders] Shop talk - washers
-> > Realized while working away today I do something subconsciously (or
-> possibly
-> > automatically is a better word). Guess I've been doing it so long I dont'
-> > give it a second thought anymore.
-> > It may have been discussed here before, but you do realize there is a
-> right
-> > and a wrong way to install a washer...right? They are punched out of a
-> > sheet....creating a sharp edge and a rounded edge. The rounded edge
should
-> > always go against the surface you are bolting together as the sharp
edge
-> > will cut into the alum and cause a stress point. Just thought I'd share
-> that
-> > tidbit of knowledge on a slow Thursday night.
-> > Cheers,
-> > Wayne
-> Wayne
-> the
mine
-> > Walter
-> Wayne
-> > G. O'Shea
-> possibly
-> right
should
edge
-> that
-> > Cheers,
-> > Wayne
Great, now I will take every washer, nut, and bolt to the scotchbrite wheel
before installing them ... and maybe install every one with proseal type-A.
That's Proseal type-A, not Type-A installing Proseal!
On 4/14/2006 6:59 AM, klehman@albedo.net wrote to rebel-builders:
-> On the worst offenders you can often also feel the sharp edge on one
-> side of the washer. Some don't have much edge but others do. I have also
-> found a few bolts with bumps or edges under the heads. They need a
more
-> careful inspection to catch but you will notice the scored aluminum
-> after removing one of them...
-> Ken
-> Wayne G. O'Shea wrote:
-> >The rounded edge side has a different shine/look to it. Easy to detect
once
-> >you've been looking purposely. I started doing this years back after
-> >disassembling airplanes and finding a nice round "cut me here" line the
-> >diameter of the washers. This imbedded line is from the sharp edge of the
-> >washer getting forced into the alum.
-> >Wayne
-> >>OK, Wayne, gotta ask this. Do you carry a magnifying glass with you all
-> >the
-> >>time in the shop? Yup, sad to say, but I guess 50% of the washers on
mine
-> >>are all wrong...
-> >>Walter
more
-> Ken
once
-> >Wayne
-> >the
mine
-> >>Walter
Bring it over in the fall Drew...I'll do it at my hourly rate for ya! LOL
Maybe I should have posted this on April 1st instead! ;O)
Wouldn't get too worried about past asssemblies...just something to think
about as the builders trudge forward!
Sent: Friday, April 14, 2006 10:21 AM
over ;(
LOL! And here I thought I was being extra fussy doing that. I've never seen it
in writing, do you know where it is?
"Wayne G. O'Shea" wrote:
David A. Ricker
Fall River, Nova Scotia
Canada
--Realized while working away today I do something subconsciously (or possibly
David A. Ricker
Canada
You've now seen it in writting David. I've never seen it anywhere else but
here!
Sent: Friday, April 14, 2006 4:50 PM
here!
seen itLOL! And here I thought I was being extra fussy doing that. I've never
possiblyin writing, do you know where it is?
dont'automatically is a better word). Guess I've been doing it so long I
rightgive it a second thought anymore.
shouldand a wrong way to install a washer...right? They are punched out of a
thatalways go against the surface you are bolting together as the sharp edge
--tidbit of knowledge on a slow Thursday night.
David A. Ricker
Canada
LOL! Now I've seen it all!
You sure this isn't 1 April?? ;o)
David A. Ricker
Canada
--You've now seen it in writting David. I've never seen it anywhere else but
here!
seen itLOL! And here I thought I was being extra fussy doing that. I've neverpossiblyin writing, do you know where it is?
Realized while working away today I do something subconsciously (ordont'automatically is a better word). Guess I've been doing it so long Irightgive it a second thought anymore.
It may have been discussed here before, but you do realize there is ashouldand a wrong way to install a washer...right? They are punched out of a
sheet....creating a sharp edge and a rounded edge. The rounded edgethatalways go against the surface you are bolting together as the sharp edge
will cut into the alum and cause a stress point. Just thought I'd share-------------------------------------------------------------------tidbit of knowledge on a slow Thursday night.
David A. Ricker
Canada
David A. Ricker
Canada
Thanks Wayne - something else to look for as I trundle on !
Nig
745E
Sent: 14 April 2006 17:08
Nig
745E
over ;(
