At 11:49 PM 4/10/2006 -0230, you wrote:
time over the Gander airport last week. The take-off and cruiseI wanted to let everyone know that C-GZZO took to the skies for the first
performance was really impressive with only gentle control inputs necessary
once the elevator trim was set. At straight and level I let go of the
stick, eased my feet off the rudder pedals and smiled ...what a nice little
airplane to fly ...!!
a little nose heavy with the firewall not cut back, an 0320, metal prop andI did place 45 lbs of weight in the baggage area thinking that I might be
an Odyssey 680 battery in the back ... but it just wasn't needed. This
first flight lasted an hour at mostly high rpm settings as recommended by
the engine re-build people. Oil temp was a little on the low side I think
(170 at cruise with the oil cooler on the firewall and an in-line remote
filter installed) and my cylinder head temps at high rpms were at 375 to
around 420 on the hottest cylinder. EGT readings on all 4 cylinders were
also high at full rich, as much as 1550 at full throttle. Anyone else
notice this with the Westac gauge and stainless steel exhaust? I can
further increase the EGT with mixture leaning so I don't think that I'm
running too lean at the full rich setting. I'll have to investigate this
some more.
much of their time and efforts in answering questions and giving helpfulMy sincere thanks to the many members of this group who have dedicated so
advise. And finally...to those of you who still have a ways to go and are
perhaps wondering if all this time and money is really worth it. Well,
keep cutting, filing, drilling and pulling rivets because your building an
absolutely wonderful airplane and will soon be the envy of all your pilot
friends. It is worth it !!
Clay Smith
Rebel 460
I'm posting a picture to the site this evening.
