like to meet you sometime and was concerned with the compromised integity of
the "D" cell for torsional strength.
Sounds like I wasn't being over cautious, but reading your letter to Darryl
you state "5 bays out from the lift strut attach". In your original post
here you'd stated very close to the lift strut attach. How many bays in from
the tip is 5 out from the strut? I guess I could look at my pictures...but
figure easier to ask.
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Monday, April 03, 2006 9:24 PM
Subject: [rebel-builders] Landing light location and wing mount
mySome of you may remember that I questioned the list about the location of
askedlanding light and Wayne pointed out that it wasn't a good idea to put it
where I did. If you've got an exceptional memory you might remember I
kindthe list ages ago about my wing attach fittings being right up against the
forward attach point on the fuselage instead of somewhere in between. I
posed those questions to Murphy technical and thought Darryl's reply might
be informative to others. I found it interesting that the spar is not the
issue. It's the break in the leading edge skin. A reminder that this
theirof structure is a stressed skin design, where the skin accounts for a
significant amount of the structural integrity.
044SR
P.S. I would also like to mention for the record that I have posed some
questions recently to Murphy technical and have been very pleased with
cases.timely and helpful responses, directly from Darryl in the most recent
where-----Original Message-----
From: Robin Dyck [mailto:rdyck@murphyair.com] On Behalf Of Murtech Mailbox
Sent: Monday, April 03, 2006 9:48 AM
To: Mike Kimball
Subject: RE: Landing light location and wing mount
Hi Mike
I hate to deliver the bad news but I think the light should be moved out
to one of the outer bays. The front spar is not the problem. The
problem is the leading edge which resists the torsion applied to the
wing. I can not say for certain that it is compromised with out a load
test but I can tell you that when doing the wing loading tests the
leading edge distorts considerably and with the cutout it might not
return to normal. My suggestion would be to put a 0.032" patch over the
cutout ensuring that a least one stringer top and bottom is picked up.
Make up a single spacer of aluminum with as large of diameter as you can
to replace the two Delrin spacers. Having one spacer will reduce the
bending load on the attach bolt.
Darryl
Sent: Sunday, April 02, 2006 10:01 PM
To: Murtech Mailbox
Subject: Landing light location and wing mount
I recently discovered that there may be an issue with where I mounted my
leading edge landing lights. I apparently wasn't paying enough
attention to the instructions and mounted your kit 5 bays outboard of
concernedthe lift strut attaches. Apparently, it was supposed to be limited to
either the outermost bay, or one bay inside of that. Should I be
thewith compromising the forward wing spar at the point where I mounted the
light?
Also, on a different topic, when I mounted my wings to build the lift
Struts I discovered that the forward spar attach point on the wing was
butted right up against the forward part of the fuselage attach point (the
square tube) when the rear attach point was in place. I expected the wing
attach to be somewhat centered in the square tube. Is this an issue or
should I simply put both delrin (I think they are delrin) spacers behind
andwing attach and not worry about it? Mine is a Super Rebel, not a Moose,
I understand that the Super Rebel has the wing attaches fixed solidly with
the spacers.
Thanks.
044SR
