If you do it that way make sure you have the bottom exterior corner wraps
clecod securely on to hold the bulkheads in alignment. I haven't even
riveted the bulkhead quarter sections together, so while working on the
interior floor I only have half the bulkhead to get in my way. However, when
fitting and drilling the side channels I think I had the roof and sides on,
and top corner wraps on one side to hold everything in alignment. This lets
you work through the space where the top corner wrap would be on one side,
then put that one on and take the other one off. I think this is only a
concern when fitting the side channels, because they help establish the rake
angle of the bulkhead side. Once the side channels are in you can remove the
fuse sides and just cleco the side channels to the corner wraps and you have
your bulkhead alignment for working on the inner floor. You get the idea.
Just be careful because everything you drill effects alignment of the whole
fuselage. Mine worked out well though. Yesterday I finished
drilling/clecoing the inner floor with roof, sides, and upper corner wraps
removed, then put the whole thing together, and alignment is perfect. A
trick for drilling the inner corner wraps where they join the bulkhead
radius; drill #40 holes in the bulkheads, drill inner wrap along channels
side and bottom and cleco. Remove outer corner wrap and drill through
bulkheads. Cleco outer wrap back on and drill inner wrap to#30. Works great.
Subject: Re: [rebel-builders] Rebel baggage floor thickness
Date: Thu, 30 Mar 2006 21:27:44 -0900
Adding my thanks in here too as I am at the point of drilling and riviting
on
the sides,top and bottom. Will wait for sure on the riveting now after
this
advice.
-Ben/496R
whatThanks for the moral support Walter,
Yes, it is a real pain. Like you said though, I haven't riveted anything
yet, so I have removed the sides and top, allowing me to build the floor
with my feet standing comfortably on my workshop floor. I can't imaginewella huge pain it would be to do all that work while laying on a board.
Date: Thu, 30 Mar 2006 10:26:50 -0800
Hey, Jesse, although it's been a long, long time, but I still rememberdoingmessing with all those ST31's and brackets, and curved panels whentookthe fuselage floor. It definitely tested my patience, as I recall, andhelped,a lot more time than I expected, so you've got my sympathies. Whatthough.though, was not riveting the fuse sides and top, so that I could more
easily access everything for fitting. It took a lot of clecos, but that
sure helped. Good luck, and sounds like you're moving right alongforwardWalter
Date: Thursday, March 30, 2006 9:26 am
closefloor.theup
