leak test...
leak test...
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:22 pm
Sent: Thursday, February 09, 2006 8:14 PM
Subject: Fwd: leak test...
jean.poirier
leak test...
Post by jean.poirier » Sun Feb 19, 2012 1:22 pm
Hello
Tonight I have pressure tested my right wing tank. Looked ok except a "popup" in
a proseal joint at one top stringer. I have mix some proseal, put it in a
syringue, shoot it in the hole, put the shopvac on the hose. when the proseal have
been suck inside, I have cut the vacuum, and put more proseal. I will wait couple
more days and make a new test. Is there a better tkick?
Jean
Rebel 747R
jean.poirier
leak test...
To: rebelbuilder@dcsol.com
Sent: Thu Feb 9 20:07
Hello!
I have pressure tested my right wing tank tonight....
leak test...
How much pressure (psi) you putting in there to get a "pop up"? and you have
let the proseal cure for a couple weeks minimum before trying the test I
hope?
Sent: Thursday, February 09, 2006 8:28 PM
Subject: leak test...
Hello
"popup" in
proseal have
wait couple
Jean
Rebel 747R
jean.poirier
leak test...
Hello Wayne
No not couple of weeks, couple of days! So better proseal the second wing
before make the second test? Probably 1 psi, I have a gauge 2-15 psi that I fit
on the tank and it was not showing pressure but the latex glove was well inflated!
Jean
Rebel 747R
On Thu Feb 9 20:33 , 'Wayne G. O'Shea' <oifa@irishfield.on.ca> sent:
hope?
To: rebel-builders@dcsol.com>
Hello
"popup" in
proseal have
wait couple
Jean
Rebel 747R
leak test...
Don't be so rushed! I leave them for a couple weeks before pressure
testing...especially in cool dry time periods as the Sealpac takes longer to
cure in the winter. Glove inflated is all I was hoping to hear. No need for
a pressure gauge.
Sent: Thursday, February 09, 2006 9:04 PM
Subject: Re: leak test...
Hello Wayne
wing
that I fit
inflated!
Jean
Rebel 747R
have
hope?
Hello
"popup" in
in a
proseal have
wait couple
Jean
Rebel 747R
jean.poirier
leak test...
As usual... thank you very much!
Jean
No plan for the Sun'Fun?
On Thu Feb 9 21:09 , 'Wayne G. O'Shea' <oifa@irishfield.on.ca> sent:
a pressure gauge.
Hello Wayne
wing
that I fit
inflated!
Jean
Rebel 747R
On Thu Feb 9 20:33 , 'Wayne G. O'Shea' oifa@irishfield.on.ca> sent:
have
hope?
"popup" in
in a
proseal have wait couple
Bruce Georgen
leak test...
Post by Bruce Georgen » Sun Feb 19, 2012 1:22 pm
I have returned to the shop and seen that latex glove sucked completely into the tank and watched it inflate again after the shop heated up. Don't think it has a leak if the glove deflates. Heat the shop to the same temp and see if it re-inflates first.
Bruce G
Sent: Feb 9, 2006 9:16 PM
Jean
a pressure gauge.
Hello Wayne
wing
that I fit
inflated!
Jean
Rebel 747R
have
in a
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
leak test...
Nope....if I go anywhere it will be warmer than Florida.... but that will
only happen if Leah needs a health break. Amphibs to finish building and
install before May, Clamar's to put on White's Elite last week of
April...and many other projects that must be completed before Pickeral
opener on May 21st .....and I want nothing left hanging around here to make
me come back home before October!!
Sent: Thursday, February 09, 2006 9:16 PM
Jean
for
a pressure gauge.
Hello Wayne
second
wing
that I fit
well
inflated!
Jean
Rebel 747R
you
have
except a
it
in a
will
