Yep...still planning on the 4 cylinder 160hp diesel when it's available. The
3 cylinder 120 hp is shipping now, and the first Elite in the UK will
hopefully be flying in a few months behind one of these. He will use the 2
blade MT vp prop with it. He's on the frappr map !
They are hoping to get certification for the 120 hp engine later this year,
and that has delayed mine another 6 months, but since I haven't finished the
wings yet it's not a big deal yet.
www.wilksch.com
There is already a mount designed for both the 120 and 160 engines for
Rebels and Elites
Officially it's Jet A1 only, but should be fine on road diesel, probably
home central heating oil as well :-)
Nig
Jesse Jenks
Sent: 21 January 2006 17:17
Subject: Re: Rebel engine choices
Hey Nigel,
Maybe you could give us an update on your engine installation. If I remember
correctly you are using a new diesel engine design right?
Date: Sat, 21 Jan 2006 08:59:28 -0500
Sounds reasonable to me except I'd amend the last line to a LOT heavier
(as in 100 lbs more) and NOT cheaper if you want a reliable installation
worthy of being on a Rebel. "Reliable" probably precludes anything over
100 real or imaginary hp. A significant percentage of the problems with
engine conversions seem to stem directly from mods attempting to get
more hp. When one doesn't care about low end torque (driveability) you
can usually do a few things to get a bit higher peak power at high rpm
but then there is the question of durability. Internal engine forces
tend to be related to the rpm squared.
bransom@dcsol.com wrote:
tooBob, John, any others on this one...
Yep I'm not surprised at your answer. The ramengines numbers do soundRebels andgood to be true. Still, I have heard of people running EA81s ingeneral.there seems to be a lot of EA81 conversion experience out there input out aI'll assume that if done well it could compare with a 912S, perhapsto makebit more power, a bit heavier, a lot cheaper, and a lot more tinkeringit go reliably.
-Ben
Hi Ben !
Here we go again !! The EA-81 is a great little engine -
about 80 hp. in the car. These guys claim 140 hp - that makes
them about 75 % smarter than the Japanese automotive engineers !
If you believe that, you might also believe their claim that
the whole engine installation will weigh less than about 240++ lb...
Don't know the company, and not knocking them specifically,
but several people have tried to squeeze more out of EA-81's.
I think Frank is still flying happily with his <STOCK> EA-81 Rebel,
but total weights would make LSA a real stretch !
Generally, for just a few pounds more, you are better off
with an EJ-22 or EJ-25 - a lot more power --- but not LSA !
On Friday 20 January 2006 12:30 pm, bransom@dcsol.com wrote:
