Hi Mike
I am now unable to post selecting "Private". If I click reply and change to
Private, I am unable to write in the message block. If I leave it "Rebel-
Builders" I can type away like a madman, but then sadly it is vaporized when I
then click to select Private conference.
Bob -- I was going to tell you about another flying NSI (not a
Murphy) ...although perhaps it is one of the 3 you already know about.
-Ben
unable to post private
Mike Davis
Ben if you log into the web you'll have an e-mail from an account I setup toHi Mike
when I
-Ben
test this... but for your information as well as everyone elses.
I applied some updates to the site today, and one of the major changes was
the message posting template. The new template uses Java to allow certain
changes to be made, but here is what I discovered regarding the issue above.
After I hit reply and changed the message conference to 0-Private e-mail, I
was not able to click in the message body and type a reply. However, if I
clicked in the subject line first, then clicked in the message body, I was
then able to type my reply. Now this isn't the behavior we want to see, and
we'll be looking into why this is happening... but for now, this will work
if you're posting via the web interface.
Thanks Ben, but it's probably just as well. I never post using the
web interface, nor read the private section ...
I find it easier to just use Kmail or Thunderbird email - you can
always email me directly - the address is in the email headers..
beep@sympatico.ca
Glad to hear at least one more person got what he paid for ...
at least, enough that he got it flying.
.......bobp
beep@sympatico.ca
.......bobp
Hi Mike
to Private, I am unable to write in the message block. If I leave it
"Rebel- Builders" I can type away like a madman, but then sadly it is
vaporized when I then click to select Private conference.
-Ben
