de-burring tools
David L. Tuck
de-burring tools
Post by David L. Tuck » Sat Feb 18, 2012 2:41 pm
Does anyone have advice on de-burring tools? what is the best type to use?
There seems to be alot of holes!
Dave T/ Rebel #009
de-burring tools
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:41 pm
17/64 drill bit...rolled in your hands preferably...or once they've packed
it in like mine attached to a cordless screwdriver with a piece of rubber
hose. Pretty much anything else is counter sinking and that's not what you
want!
Sent: Friday, January 13, 2006 7:49 PM
Subject: de-burring tools
Dave T/ Rebel #009
de-burring tools
I meant 27/64 ! Anything between about 3/8 and 7/16 works well.
Sent: Friday, January 13, 2006 7:55 PM
Subject: Re: de-burring tools
want!
use?
Dave T/ Rebel #009
Dale Fultz
de-burring tools
Post by Dale Fultz » Sat Feb 18, 2012 2:41 pm
I will put my two cents in here that after doing enough it will just be
natural doing it . Your fingers will get numb to it. If you don't think
about how bad it really is doing them it will go faster. Ya it's not the
best job in the building process but it needs done so a person might as well
make the best of it and just do it and move on there's no getting around it.
I'm sure someone like Wayne would have come up with something better for
this job if it was out there. Dale SR-033
Bob Andrews
de-burring tools
Post by Bob Andrews » Sat Feb 18, 2012 2:41 pm
http://www.yardstore.com/index.cfm?acti ... ategory=25
Bob 612e
Dale Fultz
Sent: Saturday, January 14, 2006 5:38 AM
NormIsler
de-burring tools
Post by NormIsler » Sat Feb 18, 2012 2:41 pm
I don't have as much experience as some, but after "only" a couple of
thousand holes, my weapon of choice for deburring is the one shown below. Easy on
the wrist and fingers... just don't over do it in the thin parts!
_http://www.aircraft-tool.com/shop/detail.aspx? ... rnPage=/sh
op/flyer.aspx?PageNo=1_
(http://www.aircraft-tool.com/shop/detai ... x?PageNo=1)
Norm
Elite 702E (http://www.aircraft-tool.com/shop/flyer.aspx)
Bob Andrews
de-burring tools
Forgot to add this link ... the rest of the story ...
www.aacnet.com/elite/misc-pics/DSC03832.JPG
any SLOW RPM drill with a chuck will do the job ... aproximately two
revolutions on each side of the hole does a most excelent job.
Bob 612e
Dale Fultz
Roger Cole
de-burring tools
Post by Roger Cole » Sat Feb 18, 2012 2:41 pm
I find that split-tip drill bits don't work as well as the
old-fashioned standard tip. The standard tip pilots in the hole, but a
split tip tends to chatter.
-------------Roger, Elite 709E
packed
rubber
what you
want!
use?
Dave T/ Rebel #009
de-burring tools
Yep..plain old jobber bits. I can't afford those split tips Roger! :O) LOL
Sent: Saturday, January 14, 2006 11:47 AM
packed
rubber
what you
want!
use?
Keith Leitch
de-burring tools
Post by Keith Leitch » Sat Feb 18, 2012 2:41 pm
I got a duburring tool from Avery:
https://www.averytools.com/cart/pc-428- ... utter.aspx
It fits in a cordless screwdriver and works great. I
started out with the drill bit in the fingers but this
is many times faster and no sore fingers. Just keep an
extra battery charged. You can do a whole mess of
holes in a matter of minutes. Good luck.
Keith R661
Do You Yahoo!?
http://mail.yahoo.com
Bob Andrews
de-burring tools
Using counter sinking cutters like this tend to over cut the hole if you're
not real real careful ... all you really want to do is get the bur off. The
more cylindrical the hole is the better. Actually, hitting a line of holes
(that won't be visible to the eye when the aircraft (or float) is complete)
with a scotchbrite wheel (in a die grinder or just holding it with your
hand) does the trick.
Bob 612e
Keith Leitch
Sent: Saturday, January 14, 2006 9:53 AM
Keith R661
Do You Yahoo!?
de-burring tools
Post by Ken » Sat Feb 18, 2012 2:41 pm
Yes and oddly my preferred size for easy finger spinning is about the
first smaller size that Wayne mentioned of around 1/4". Even stranger,
once I found the bit that worked best, it became my favourite and a
randomly picked up bit just wasn't as good ;) A 6 flute 1/4" 120
degree countersink in my fingers also worked very well for me. Often if
there was still a burr after using the drill bit, a quick swipe with
about 150 or 180 grit aluminum oxide sand paper finished it nicely.
Some guys just go down the rivet line with a scotch brite finishing disk
in a drill. I stuck with the drill bit and fingers. I didn't really like
the single cutting countersink in the electric screwdriver although it
worked if you were careful. Counting the rework I figure I've deburred
just over 100,000 hole faces (at least four faces per rivet). Only 40 or
50,000 more to go in the floats I'd guess...
packed
rubber
what you
want!
