Airspeed Indicator for the Rebel
I beg your patience on this one guys, but I am new at this
rebel is slow plane so you need airspeed that is below 150,thats even to
much, i found good asi with expanded scale for low speed aircraft, forget
where but will look it up this weekend, did not cost alot either, only think
you add to asi is the colour zones for the warnings speeds, nothing to get
silk screened on, the color zones n mine are stickers
mike#007
pequeajim@dcsol.com
Sent: Friday, December 16, 2005 11:18 AM
Subject: Airspeed Indicator for the Rebel
mike#007
pequeajim@dcsol.com
Hi Jim !
No need to buy new ! The speed range arcs are just narrow
vinyl tape that you can buy at art supply stores - or even just
paint !! You stick them on to suit your model.
The important thing is to have a good spread at the low end -
ideally one that starts at 20 mph, and has a wide space to 40 and
60 - ok if spaces are smaller over 100 mph ... I had an old one
with a log scale that was great, but these are hard to find - think
it went one and a half revolutions !
As several have already said, it's not that important, because
ASIs are usually inaccurate in Rebels, because of the wide range of
speeds and attitudes, and the difficulty of getting a good static
source. You will get a relative indication - note whatever it
reads at stall, for reference, and have fun ! (Have seen readings
at stall from zero to 60 mph, in different Rebels !! )
On Friday 16 December 2005 11:17 am, pequeajim@dcsol.com wrote:
[quote]I beg your patience on this one guys, but I am new at this
Aircraft Spruce sells a range marking kit for about $4. Curved range
decals for large and small size instruments,.
Bob Patterson wrote:
Hi Jim !
snip
Thanks, I wil check that out. Where is a good place to buy the rest of the
instruments. I have looked at Aircraft Spruce, Chief, Barnstormers...
On 12/16/2005 9:35 AM, klehman@albedo.net wrote to rebel-builders:
-> Aircraft Spruce sells a range marking kit for about $4. Curved range
-> decals for large and small size instruments,.
-> Ken
-> Bob Patterson wrote:
-> >Hi Jim !
-> > No need to buy new ! The speed range arcs are just narrow
-> >vinyl tape that you can buy at art supply stores - or even just
-> >paint !! You stick them on to suit your model.
-> >snip
-> Ken
-> >Hi Jim !
-> >snip
the asi i found and a using has what appear to be a pretty large scale,
10-160mph, 20-140kts, scale cover the whole dial as well, its is made by
falcon model asi164mn-3, got it from place called sky star aircraft
corporation on the web, sure others must sell this item
mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Ken
Sent: Friday, December 16, 2005 1:36 PM
Subject: Re: Airspeed Indicator for the Rebel
mike#007
Hi Jim !
snip
Thanks Mike:
I think that will do just fine for me.
Skystar isn't around any more, (what a crime), but I believe that Chief
carries Falcon.
On 12/19/2005 3:13 AM, michael.jones@snclavalin.com wrote to rebel-builders:
-> the asi i found and a using has what appear to be a pretty large scale,
-> 10-160mph, 20-140kts, scale cover the whole dial as well, its is made by
-> falcon model asi164mn-3, got it from place called sky star aircraft
-> corporation on the web, sure others must sell this item
-> mike#007
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Ken
-> Sent: Friday, December 16, 2005 1:36 PM
-> Subject: Re: Airspeed Indicator for the Rebel
-> Ken
-> >Hi Jim !
-> >snip
-> List archives located at: https://www.dcsol.com/login
-> Subscription services located at:
-> https://www.dcsol.com/public/code/html-subscribe.htm
carries Falcon.
-> mike#007
-> Ken
-> >Hi Jim !
-> >snip
