Door latches
mbetti
Door latches
Post by mbetti » Sat Feb 18, 2012 2:18 pm
Is the std MAM door latch the way to go or are there better options? With the MAM setup it looks like you just pull the cable running along the door to open it?
Mike Betti
771E
Door latches
Post by Drew Dalgleish » Sat Feb 18, 2012 2:18 pm
to open it?
Mike Betti
771E
The MAM doorlatch is light and simple it works well the same system as my
57 MGA had. You're right to open it you pull on the cable no double
jointedness required. To get a perfect fit wait until after you hang your
engine the fuselage will spring slightly messiing up all your carefull work.
WALTER KLATT
Door latches
Post by WALTER KLATT » Sat Feb 18, 2012 2:18 pm
I too have the stock MAM doors and latches. I have seen many mods here with other planes, and some definitely appear more elegant. However, there is something very important to consider if you are going on floats. And that is how you will exit the cabin if you end up upside down in the water. The MAM latch mechanism is definitely easy to open and worst case, you can just push or kick the door open if you have to during an emergency. What you don't want is a latch system that is hard to reach or find, and worse that locks the doors so securely they can't be opened without operating the latch.
Date: Tuesday, November 8, 2005 8:10 am
Subject: Re: Door latches
options? With
the door
to open it?
Mike Betti
771E
system as my
hang your
carefull work.
Door latches
Post by Mike Kimball » Sat Feb 18, 2012 2:18 pm
I took a little piece of aluminum angle (1-inch I think) and fashioned a
simple door handle. I put it near the front of the door and ran the cable
to it. I just push down on the piece of angle and the door releases. Later
I added some bolt locks for a Recreational Vehicle. They have a very small
profile on the outside and they fit the 1-inch door great after shaving off
a bit of the actuator shaft. I got three of them and paid about $20 to have
them keyed alike. Now that I have those I'm wondering why I even bothered
with the MAM spring catch.
mbetti@up.net
Sent: Tuesday, November 08, 2005 5:30 AM
Subject: Door latches
to open it?
Mike Betti
771E
Alan Hepburn
Door latches
Post by Alan Hepburn » Sat Feb 18, 2012 2:18 pm
Mike:
There seem to be more ways to handle the doors than there are builders. I
built mine standard, but used stronger hinge material for the lower door
(closed loops as opposed to bent over ones at the hinge). On the latch, the
Murphy one actually works very well, but it has a couple of drawbacks. You
cannot open a closed door from outside. So if you have a floatplane and
turn it at the dock, you have to remember to open the opposite door before
you turn the airplane. Also, when it comes to final inspection, the
inspector will want to see a way of opening the doors from the outside in an
emergency. This can be taken care of by providing a removable pin on the
hinge, with a placard. There doesn't appear to be any real easy way of
modifyingthe standard door so it is openable from the outside, though I
imagine a way could be devised to operate both top and side latching
mechanisms, yet have them lockable when you leave the airplane.
Al
Jones, Michael
Door latches
Post by Jones, Michael » Sat Feb 18, 2012 2:18 pm
hi all
i have outside paddle latch (from mcmaster-carr in cleveland) and handle on
inside, i think there are pics on web site of my doors, forget what under,
mine woks with rods right now but hope to do another redesign and use
cables, but it works great now as well
mike
Alan Hepburn
Sent: Wednesday, November 09, 2005 7:36 AM
Mike:
Al
Door latches
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:18 pm
We made both of Howard's windows open from the outside simply by using a
small peg off the delrin plugger out thru the doubler/lexan. This way you
can't lock your keys in the plane either by accident as you can with the
standard set up. Had to put a lock on both windows though...same key and not
a real issue.
I'll take a picture today if I remember.
Mike:
You
an
Al
steve whitenect
Door latches
Post by steve whitenect » Sat Feb 18, 2012 2:18 pm
Can someone (in Canada) show me something in writting that states the
aircraft has to be accessable from the outside in case of emergency? Maybe
I'm out of touch with regulations but just about every Cessna 172 and up are
not accessable from the outside and they are still making and importing the
new ones configured the same way. Once the door latch is dropped, that's it
unless in the panic the pilot opens the door before impact. Maybe I'm wrong
but I understood this grew from some designated inspector's brain fart of an
idea thrusted upon the homebuild world.
Steve W.
Rebel 637
Date: Wed, 9 Nov 2005 07:36:09 -0500
Mike:
an
Al
Door latches
Cessna hinges have a pin that is pullable. We take the door off a guys C182
for each young eagles day and he keeps the door locked! It's how we get in
to move his airplane twice a year.
Don't know where it's located in the regs (or if it even is) but was a main
item with the inspection system back in 1995. All hinge pins had to have
extra on them to form a loop or 90* bend at the top for pulling. Has to be
labelled in case of emergency pull pin to remove door. I was even asked to
remove the work rescue as "some dumb farm boy" may not know what that means.
...and I forgot to take the picture of the protruding pin for the window
latch.
Sent: Wednesday, November 09, 2005 2:56 PM
are
it
wrong
an
Steve W.
Rebel 637
Mike:
You
before
an
Al
Door latches
I'm getting confused due to the lack of reference to what type of plane is
being discussed. Now I believe this thread has to do with the Rebel.
Earlier posts on this subject talked about the "pull the cable" method of
releasing the spring catch. It sounds like at least that much is similar
between the Rebel and Super Rebel. If the Rebel doesn't have an outside
latch then perhaps a review of the Super Rebel design will provide the
answer. It's a very simple mechanism and I wouldn't be surprised if it
would work for a Rebel. I can scan in the relevant pages of the manual and
upload them to the archives or email separately if anyone wants to see how
it's done on the Super Rebel.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Alan
Hepburn
Sent: Wednesday, November 09, 2005 3:36 AM
Mike:
Al
Mike Betti
Door latches
Post by Mike Betti » Sat Feb 18, 2012 2:18 pm
I believe I started this thread for my Elite. I'm interested in any pic you
have.
Mike Betti
771E
Sent: Wednesday, November 09, 2005 8:23 PM
Subject: RE: Door latches
Hepburn
Mike:
You
an
Al
Mike Davis
Door latches
Post by Mike Davis » Sat Feb 18, 2012 2:18 pm
God... don't let TSA learn that you can get into any Cessna by pulling a
pin, they'll out right ban GA!
Sent: Wednesday, November 09, 2005 1:27 PM
C182
main
means.
latch.
Maybe
are
it
wrong
an
Steve W.
Rebel 637
Mike:
You
before
in
an
Al
__________ NOD32 1.1282 (20051109) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
Door latches
I once flew a rental C-172 into Fullerton Airport to go to Disneyland with
friends. After a long day and part of the night with Mickey, I returned to
the airport, put my key in the lock and opened the door. I was dismayed to
see all of my stuff missing until I looked closer and realized it wasn't my
172. I eventually found mine which had been moved elsewhere. I also owned
an Arrow 180 and was always forgetting my key when going to the airport to
fly. It didn't matter. Many keys, including the key to my desk worked in
the doors and ignition. Just find something close and off you go. As long
as the spam cans with thousands of dollars of avionics keep being issued
with $2.95 door locks that door pin issue is moot. And the $2.95 locks on
30+ year old airplanes have been worn so bad they'll accept almost anything
you can jam into it.
Sent: Wednesday, November 09, 2005 6:44 PM
C182
main
means.
latch.
Maybe
are
it
wrong
an
Steve W.
Rebel 637
Mike:
You
before
in
an
Al
http://www.eset.com
Mike Davis
Door Latches
Post by Mike Davis » Sun Feb 19, 2012 5:54 pm
Just a reminder for everyone... if you send me email from the public login,
please include your email address so can reply.
Herb, wasn't me, I haven't even started on my fuselage yet.
To: <mike.davis@dcsol.com>
Sent: Wednesday, December 30, 2009 10:16 AM
Subject: Door Latches
Hello Mike
Can you please give the manuf., or a supplier of the SS door latches that
you
used. do you know if they are the same ones that Ron Kakeldey used?
Herb Williamson
