Does anyone have any experience or thoughts regarding the 120 hp
turbo-prop engine Watson is touting? I can't quite be sure they're
actually selling them.
145 lbs
120hp @ 2800 prop rpm
owner maintainable and rebuildable
6000 hrs tbo
runs on used dirty french fry grease
http://www.watsonflight.ca/maintenance.htm
Is it once again too good to be true?
I am aware that it doesn't qualify under USA Sport Pilot rules, but
impressive specs.
John...
Watson ~Yukon goes Turbine (Turbo-Prop)
At 01:07 PM 11/1/2005 -0600, you wrote:
yet. Also 7.5gph sounds awfully optomistic for a turbine.
Well when all the pictures of it are on a cart I suspect it hasn't flownDoes anyone have any experience or thoughts regarding the 120 hp
145 lbs
6000 hrs tbo
impressive specs.
John...
----- Original Message ----- getting this message:
[quote]
from: Mail Administrator <Postmaster@bellnexxia.net>
This Message was undeliverable due to the following reason:
Each of the following recipients was rejected by a remote mail server.
The reasons given by the server are included to help you determine why
each recipient was rejected.
[quote]
