Stabilizer Mod (Moose) What About Elite?
Dave Ricker
Post by Dave Ricker » Sat Feb 18, 2012 5:01 pm
I've been watching this discussion and wondering what the implication is for
Elites which I believe are made the same way, anyone know anything/opinions
about this?? (knowing Wayne has seen both ;o)
elite583.cjb.net
Warren & Marg Montgomery wrote:
I haven't seen MAMs mod but I had made my tip ribs from ,040 with a
doulbe wide flange and second row of rivets.
I wonder if I need bother with this mod? Or maybe at most tie into the
stringers?
Warren
Mike Davis wrote:
The cracking was at the bend of the rib flange at the rear spar.
Sent: Friday, October 07, 2005 8:05 PM
Subject: Re: Stabilizer Mod
Wow, now I have to think! The mod currently installed looks pretty clean.
It picks up the rib over less area than the SS plate mod, but that is the
only advantage that I can see for the SS plate mod. It picks up the spar
over more area (all four bolts) than the SS plate mod. Where was the
cracking that led to the mods in the first place? I just ordered the
upgraded rib and the sea fins today so I have some time before I can do
anything.
Sent: Friday, October 07, 2005 8:48 PM
Subject: RE: Stabilizer Mod
__________ NOD32 1.1246 (20051007) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
David A. Ricker
Fall River, Nova Scotia
Canada
Post by Wayne G. O'Shea » Sat Feb 18, 2012 5:01 pm
Doubt it's an issue on the Elite Dave...unless you start running a radial
with a 10" paddle prop! No signs of Stab/Elevator problems on the one we
just put thru TC's inspection on Thursday am to move it from an N # to
C-FFIB (should have gotten C-CNIB considering how much of a joke the import
inspection was)! The machine needs the elevator horn SB performed...and I
tried to convince the owner to do both it and the spade "cut in half"
process at the same time while it's apart. He is going to fly it next season
instead and decide if it's really too twitchy, then I will pull the
stab/elevator for the horn mod and if wanting the spade mod. He seemed
happy with the way if flew during his 18+ hours of flight from California,
so is hesitant to cut the spades in half.
This is the airplane by the way!
http://www.murphyair.com/complete/Tohikian6.htm
Sent: Saturday, October 08, 2005 5:25 PM
Subject: Re: Stabilizer Mod (Moose) What About Elite?
for
anything/opinions
elite583.cjb.net
stringers?
Warren
clean.
spar
do
is as
bolt
with
piece
then
has
nice
know
Of
is
Of
angle
spar
one
David A. Ricker
Canada
