I'll jump in here - Your best bet is to ask Prince for their
recommendation on pitch for your particular setup. The Prince prop
changes pitch with load, so their numbers are QUITE different from
everybody elses ! :-)
I think they will suggest a 74 x 44 for your 160 hp, for floats,
but best to just ask them - if they are wrong, and it doesn't perform
the way you want, they WILL replace it !! They've done this before !
FWIW, the Prince on Pierre's weighed about 9 lb. - pretty impressive,
considering it has the metal leading edge protection, as well as
carbon-fiber coating. Dale said that he got 100 fpm more climb than
the Sensenich, and the same cruise, on Murphy 1800 amphibs !
On Wednesday 28 September 2005 08:53 pm, Bob Fisher wrote:
athanks much bruce thats a heavy prop , like mine any comments on
relative efficiency?
if you were buying a Prince-- which length and pitch would you order with
160 hp engine?
bob fisher
Sent: Wednesday, September 28, 2005 7:25 PM
Subject: Re: RE: Which o 320 is in your Rebel?
front and rear plates, spacer and bolts.I weighed my Sensenich prop (74x56) and it was 40 lbs. with nose cone,________________________________________
