I spent over nine hours today drilling, cutting, filing, deburring, and
Scotchbrighting. My arms are exhausted, but I now have a perfect new skin. I
used a spacer between the original skin and the blank and an egg cup
bushing as discussed. I used card stock about .030 thick which seems about
right. The majority of the holes stayed centered, and a few showed signs of
wandering in the original skin. The moment of truth will come tomorrow when
I cleco the new skin in place on the wing, but at this point it's going on
one way or another. After this ordeal I will remove the plastic from my
skins with a toothpick if that's what it takes to not dent them.
Skin blemishes/making a new skin
Hi Jesse,
Sounds like you had quite the ordeal. I
Thanks Jeff,
I may end up using some 5/32 rivets before this is over. I do realize that I
will have to accept some imperfections during the build process, but I want
to do my best within reason. Once it is born out into the real world I'm
sure there will be plenty of dings and scratches, but I want to start out
with nice airplane.
Where do you get those 5/32 Avex rivets? I think I saw them in the ACS
catalog, but they are probably $1.00 each or something like that.
[quote]From: Jeff McMurrer <westcoastkitplanes@shaw.ca>
Subject: Re: Skin blemishes/making a new skin
Date: Sun, 04 Sep 2005 08:42:03 -0700
Hi Jesse,
with nice airplane.
Hi Jesse,
Call MAM they will sell them to you.
Sent: Sunday, September 04, 2005 12:07 PM
Thanks Jeff,
want
with nice airplane.
Hi Jesse,
Sounds like you had quite the ordeal. I've had to replace a few skin
s here and there over the build project time. For reasons I won't sa
y.
If you do find that some of your holes do not line up perfect or you have
too much load on the skins/rib because of forcing the holes to align.
Just remember, you can upsize the hole to 5/32 and nobody would know b
ut you.
Everything is repairable and fixable. And there will be more dents,
creases and imperfections before you're done. One of those things yo
u will have to get used to. Unless you're planning on keeping the pl
ane under a glass case, as was stated earlier by someone with experienc
e.
Keep up the spirits; it's all worth it in the end.
Jeff
Date: Saturday, September 3, 2005 5:54 pm
Subject: Skin blemishes/making a new skin
I spent over nine hours today drilling, cutting, filing,deburring, andScotchbrighting. My arms are exhausted, but I now have a perfectnew skin. Iused a spacer between the original skin and the blank and an eggcupbushing as discussed. I used card stock about .030 thick whichseems aboutright. The majority of the holes stayed centered, and a fewshowed signs ofwandering in the original skin. The moment of truth will cometomorrow whenI cleco the new skin in place on the wing, but at this point it'sgoing onone way or another. After this ordeal I will remove the plasticfrom myskins with a toothpick if that's what it takes to not dent them.
I have the new skin clecod on. The hole alignment wasn't perfect, but not
bad either. I cheated on a handful of holes and just ran a #30 drill
through. I'm pretty happy with it now though. Tomorrow it gets riveted.
Jesse:
I think the current catalog from ACS only shows countersink 5/32 Avex
rivets, so I'm not sure they carry the 'dome' head style. I ordered some
from Wicks a couple of weeks ago. Their catalog shows them all at $.10ea,
and when I asked about a quantity discount they agreed their catalog was
incorrect and the price is $0.06 -$0.10 ea depending on quantity. I believe
this is less then the MAM price.
Tom Packard
SR 043
Sent: Sunday, September 04, 2005 11:07 AM
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
Tom Packard
SR 043
IThanks Jeff,
wantwill have to accept some imperfections during the build process, but I
with nice airplane.
Hi Jesse,
y.
ut you.
e.
Jeff
Thanks Tom,
I got the new skin on without oversizing any holes, but I will remember that
for the future.
Jess
for the future.
Jess
Date: Tue, 6 Sep 2005 08:56:18 -0500
Jesse:
believe
Tom Packard
SR 043
thatThanks Jeff,
Iwantwill have to accept some imperfections during the build process, but Ioutto do my best within reason. Once it is born out into the real world I'm
sure there will be plenty of dings and scratches, but I want to starthavewith nice airplane.
Hi Jesse,
y.
If you do find that some of your holes do not line up perfect or youbtoo much load on the skins/rib because of forcing the holes to align.
Just remember, you can upsize the hole to 5/32 and nobody would knowut you.
e.
Jeff
