Filling rivets
Mike Davis
Filling rivets
Post by Mike Davis » Fri Feb 17, 2012 4:22 pm
Received: from 486dx2-80 (unverified [205.182.69.163]) by merlin.netexp.net
(Rockliffe SMTPRA 2.1.4) with SMTP id <B0003807889@merlin.netexp.net> for
<murphy-rebel@dcsol.com>;
Fri, 16 Oct 1998 12:36:45 -0400
Message-ID: <B0003807889@merlin.netexp.net>
Subject: Filling rivets
Date: Fri, 16 Oct 1998 12:44:21 -0400
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.71.1712.3
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.2106.4
Date: Thursday, October 15, 1998 7:03 PM
Subject: Re: Float Sealer
If you're worried about leaks - it's NOT necessary. If you want
to do it for looks - go ahead... I don't know of any EASY way, though !
....bobp
Ok, Bob. If you say so I have to believe you that it's not necessary, but I
do think it would improve the looks. I won't do it unless I can find an
EASY way to fill them though. I DON"T want to spend hundreds of hours doing
it. There must be something I could wipe on and wipe off - kinda like
putting grout in a tile floor. I do have a tube of some non-hardening
paintable auto body sealer I got from a friend that works at a body shop.
It claims on the tube water clean-up. If I find a way I'll share it with
you folks.
Joel
Scott Aldrich
Filling rivets
Post by Scott Aldrich » Sat Feb 18, 2012 10:51 am
I used poly fibers Superfil light weight 2 part epoxy filler. Just mixed a
little at a time and dabbed it on the hole pressing it in then wipe with
acetone. I have just painted and most of them you can not tell are pulled
rivets. As far as time, doesn't take long with practice and didn't cost
much. I know of ones with a lot of rust that have never seen salt water.
If you search archives other have used syringe to put in regular epoxy.
FWIW
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Alvin
and Glenys Adams
Sent: Saturday, August 13, 2005 4:55 PM
To: rebel
Can anyone suggest what to use and a easy way to fill the rivet
heads.Most people think this is a waste off time & money.I live in
NFLD,there are about 15 rebels here.I have seen a couple with rust marks
showing at rivets.Probably from landing in salt water occasionally.
Alvin rebel 778
FLYCFHBP
Filling rivets
Post by FLYCFHBP » Sat Feb 18, 2012 10:51 am
I filled all my rivet heads with the epoxy provided by MAM. Put it in a
syringe (Available through a medical friend?drugstore) put on a medium size
diameter needle and inject each rivet cavity. This may take 2 or 3 applications
as the epoxy shrinks on drying. If there is a protrusion of dried epoxy just
buff off the excess.
H prins R314
bransom
Filling rivets
Post by bransom » Sat Feb 18, 2012 10:51 am
I haven't taken this step, but I may. I would mix up epoxy with micro-
balloons to a thick toothpaste consistency, and use a plastic edge to putty
fill em fast -- at least it seems like it should go fast, sorta like
everything else. ;) Yes, and clear excess with acetone. Talk to a LongEz
builder and I bet they'd say to use this method -- they know it in their
sleep.
-Ben/ 496R
Alvin rebel 778
Alvin and Glenys Adams
Filling rivets
Post by Alvin and Glenys Adams » Sat Feb 18, 2012 10:51 am
Alvin rebel 778
Filling rivets
Post by Bob Patterson » Sat Feb 18, 2012 10:51 am
Hi Alvin !
I agree with "most people" ! ;-) If you are worried about it, be
sure to paint the Rebel using a HVLP spray system - this uses a lot
of paint at low pressure, so it just flows into the rivets & seals
them. Old high-pressure paint sprayers blow so hard that the paint
doesn't get into the tops of the rivets well.
If you are dipping each rivet in epoxy before intalling &
pulling, a film of epoxy will be pulled up around the stem, stopping
corrosion there. Rebels have been outside for almost 15 years
with no problems - I've only ever seen a couple of rust spots in
rivets. These are visually unattractive, but it could be 60+ years
before they become a structural concern .... and then, you just
replace the rivet !
If you really want to fill the rivets, some folks have used
veterinary syringes (large needle) filled with epoxy primer,
and put a drop into each rivet. VERY time-consuming .... this
was used by one builder to 'entertain' tourists who visited his hangar
while he was working - he handed them a syringe & put them to work ! :-)
Few stayed beyond one fill-up ! ;-) :-)
Alvin rebel 778
Rick Harper
Filling rivets
Post by Rick Harper » Sat Feb 18, 2012 10:51 am
G'day from sunny OZ Alvin !
I filled ALL / EVERY outside rivet on our Rebel .... ( and most
people think it's been solid riveted :o)
Looks great , no rust streaks & I figure that all those holes had to be
creating a bit of aerodynamic drag too ....
I used a small plastic syringe (no needle) ..... just mix up some 2
part epoxy , & squeeze & dab away ... (takes a while to get a rhythm
going)
Keep refilling the syringe with more glue .... & When it gets too hard
to squeeze the syringe - the glue is probably starting to set .... throw
it away & get another syringe out !
I left a little mound of glue on each rivet head ....
After they all set ... I LIGHTLY sanded each rivet head off to level (
That's the GLUE - NOT the rivet head !!! :o)
Took 3 days - non stop to do the WHOLE plane ...... it was a killer at
the time - but the end result looks GREAT ! :o)
Rick
541 OR
To: rebel
Sent: Sunday, August 14, 2005 8:54 AM
marks
Alvin rebel 778
Filling rivets
Ben,Scott,Bob,Mr Prins & Rick thanks so much for the advise.I will try
the two part epoxy filler.Will i have to rotate the fuselauge or can
this be done with out having rivets up.I assume it will not stay in
rivets unless they are in a flat up position.Also thanks to any other
replies i may get.
Alvin 778R
Rick Harper
Filling rivets
Use a "thick" epoxy .... & it should stay there at any angle !
Rick
541R
To: rebel
Sent: Monday, August 15, 2005 12:20 PM
replies i may get.
Alvin 778R
Jesse Jenks
Filling rivets
Post by Jesse Jenks » Sat Feb 18, 2012 10:51 am
I am planning at this time to leave my Rebel mostly unpainted. If I keep it
waxed or polished will enough of whatever product I use get into the rivet
holes to stop rust? I'm sure I will be in salt water.
From: "Alvin and Glenys Adams" <gander.electrical@nf.sympatico.ca>
To: "rebel" <rebel-builders-d@dcsol.com>
Date: Sun, 14 Aug 2005 22:20:23 -0400
replies i may get.
Alvin 778R
FLYCFHBP
Filling rivets
Filing rivet heads can be done in any position: mind you it is easiest when
the rivets are vertical.
H prins
Filling rivets
Hi Jesse !
If you're going for the 'bare' look, you should check out the
Everbright liquid nylon coating that Mike showed at the last Builders
Meeting !
It's very light, and can be applied with a rag - protects for years !
Having polished my "40 acres of aluminum" glider for 25+ years, with almost
every polish known to man, I'd say there's NOTHING out there in the WAX line
that will protect like Everbright, and it's a heck of a lot less work ! :-)
Maybe Mike will bring a sample along for another meeting !
According to the rivet manufacturer, the phosphoric (?) coating on
the steel mandrels is supposed to prevent corrosion, even across the
break where the mandrel shears off .....
replies i may get.
Alvin 778R
Filling rivets
Post by Drew Dalgleish » Sat Feb 18, 2012 10:51 am
Hi Jesse My rebel is mostly polished and like Bob I've tried almost every
product available. I sure hope none of it is corrosive because there's a
little dab of it stuffed down each mandrel hole. Whether it stops rust or
not I don't know but if there's any rust it certainly doesn't show anywhere
on my plane.
replies i may get.
Alvin 778R
Jesse Jenks
Filling rivets
Thanks Bob and Drew,
Drew, do you play in salt water?
Subject: RE: Filling rivets
Date: Mon, 15 Aug 2005 08:27:33 -0400
on my plane.
it
rivet
replies i may get.
Alvin 778R
Filling rivets
Post by Ken » Sat Feb 18, 2012 10:51 am
That is one of the interesting properties of galvanic protection such as
plain old galvanizing. Up to a point (width of the scratch) you can
scratch off the coating and the underlying metal will still be protected.
