Fibreglass question
Fibreglass question
Post by Ken » Sat Feb 18, 2012 1:43 pm
Hi
I made the fibreglass windshield retainer yesterday and it went well.
However the inside surface that was up against the windshield remains
very tacky. This is a new problem for me and I'm wondering if there is
any way to encourage that to harden. Any suggestions would be
appreciated. The outside surface that was exposed to air is OK. It is
warm here and very high humidity but there was obviously sufficient wax
in the 1 year old polyester resin to protect the outer surface from
moisture and let it harden.
thanks
Mike Davis
Fibreglass question
Post by Mike Davis » Sat Feb 18, 2012 1:43 pm
I've found that often warming epoxies and resins that are slow to cure
helps. Use a normal hair dryer... a heat gun is usually to hot.
Sent: Saturday, July 16, 2005 8:28 AM
Subject: Fibreglass question
Hi
thanks
Fibreglass question
Thanks Mike. After thinking about it for awhile, I reasoned that since
that surface was acting like laminating resin, I'd treat it that way. So
I painted a coat of resin on it and warmed it up. All is well now. I
don't know why it did that but I suspect the very high humidity around
here these days caused the problem.
steve whitenect
Fibreglass question
Post by steve whitenect » Sat Feb 18, 2012 1:47 pm
If u used masking tape, some resins draw the glue out of the tape and stays
tacky on the side that contacted the tape. Varsol or mineral spirits usually
cleans up the stuff.
Steve W
Subject: Re: Fibreglass question
Date: Sun, 17 Jul 2005 22:19:22 -0400
Fibreglass question
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:47 pm
Take some of the MEK (or what ever) activator came with the glass, squirt it
on a brush and rub it up and down the sticky stuff a few times. Seems to
work for me when in this mess.
Sent: Saturday, July 16, 2005 12:28 PM
Hi
thanks
