You mentioned these cups (and other great info) a while back. With amphibs
we are not located at a seabase ( I am not even sure where the nearest one
is) so do you have the phone number of Lake n Air?
Ryan
----Original Message Follows----
Reply-To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Subject: Re: torqe tube travel
Date: Thu, 3 Feb 2000 12:29:11 -0500
Ryan, I don't think this control "rod end" issue was ever addressed by
Murphy, they where fine having it thread in and out, in and out, in and
out,!!!!
Sounds like your are making good progress on your kit!!!!! Float
instructions are pretty good, but make sure you order a set of 20 aluminum
pump out cups from Lake n Air (or your local base) and their good rubber
plugs with the pull cord. Also note that, Howard is tired of replacing the
black Sea Dog inspection cover rings, as they constantly get stepped on and
broken. I suggest if you are using the pump out cups you won't need in there
much anyway so make up some aluminum plates to cover holes. Could just screw
down or use quick fasteners.
Blue skies,
Date: Thursday, February 03, 2000 12:22 PM
controllsWayne,
This also is not entirely true. We have rebel kit 669. Received kit in
September'99 and still have an old manual. We are installing the
buynow and notice the same restrictions. We just picked up the floats this
week, hope the instructions are better!
BB&R Amendala
Rebel #669
Date: Sat, 29 Jan 2000 10:23:53 -0500
Who knows Bob, no one gets updates to the manual other than people that
shelf!!!!(nothe newer kits! I should know, I have 5 manual sets on my book
andupdates received for at least 4 years - not even the float fix bulletin
end.I'm the guy that tried to get this one going in the first place!))
Date: Friday, January 28, 2000 11:59 PM
--------------------------------orig.--------------------------------------I thought the manual had been changed long ago on this one !
offAt 09:45 PM 1/28/00 -0500, you wrote:Rich,
If you look closely at the instructions, they do show to leave the nutothersthe contol coluum end. I didn't like the idea either (along with manyO.D.Jack W. etc.), so cut 2 short (3/16" long) pieces of 1/4" I.D X 5/16"steel tube and put one directly above and below the ball in the rod
hastravelThis will allow the rod end to swivel more on the ball and allow fullof the stick.(and allow you to lock nut both ends!) I know Bob, yours
thisandbeen threading in and out for miles and miles, but this is an easy fixdiametersooner or later that aluminum tube ends threads have got to get tired!!
Also, if you want all your rod end areas to look cleaner and have more
clearance to pinch points! Use a AN970-3 Penny Washer drilled to 1/4",
instead of the spelled out AN970-4 Washers. The -3's are the samesaidas the rod end to retain them, as opposed to the -4's that are away
oversize.
Date: Friday, January 28, 2000 7:27 PM
Subject: torqe tube travel
When I built my rebel I found that with both lock nuts tightened on the
short
torque tube from the main controll tube to the first belcrank, the
elevevator
travel was restricted. I asked tech support (Francis) about this and heRouserremove one of the lock nuts. Now when thw stick is used for eleveator
controll
the movement is in the threads on the bearing end. One of the Rebelbuilders has the same problem and has been told by three a&p's that
http://www.netaddress.com/?N=1isnot acceptable. Any comments?
Rich
____________________________________________________________________
Get free email and a permanent address at
Get Your Private, Free Email at http://www.hotmail.com
