Rebel floor
Joel Jacobs
Rebel floor
Post by Joel Jacobs » Sat Feb 18, 2012 10:23 am
Hi guys,
Still working on my cabin floor. I was wondering if I'm suppose to install
the floor between bulkheads D and E. That is directly behind the elevator
pulleys. My tailcone floor piece ends at the pulleys (bulkhead D) but the
instructions say to install inner corner wraps between D and E but say
nothing about the small trapezoidal floor piece required behind the pulleys.
Since I'll probably mount my ELT and battery back there I guess I'll go
ahead and install the floor back to E. (I'll STILL have 2 extra wraps)
Is everyone doing it this way? Any reason not to?
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
Rebel floor
Post by Drew Dalgleish » Sat Feb 18, 2012 10:23 am
I stopped my floor at D and that left me enough room to instal my ELT under
the elevator cables.
At 03:01 PM 4/4/2005 -0400, you wrote:
Hi guys,
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
rognal
Rebel floor
Post by rognal » Sat Feb 18, 2012 10:23 am
Joel,
I couldn't find anything in either my builder's manual, nor on the Murphy CD
that indicates the inner floor, and/or the inner corner wraps are to be
installed aft of bulkhead D. All the longitudinal and cross floor channels
are installed between bulkheads 'A' and 'D'in my manuals (#687).
Roger Hoffman #687R
Eugene, OR USA!
Rebel floor
Post by Walter Klatt » Sat Feb 18, 2012 10:23 am
Any Rebels in the Guelph or Brampton areas? I will be out that
way this Friday, but not sure how much time I will have.
Sent: Monday, April 04, 2005 4:45 PM
Subject: Re: Rebel floor
Hi guys,
have 2 extra wraps)
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
Rebel floor
Post by Ken » Sat Feb 18, 2012 10:23 am
I think the reason not to is weight but I did it anyway. Having a floor
behind the elevator pulley is of little advantage but I'd want to make
sure the battery mount was crash resistant and the ends of the channels
for that should probably be tied with something even if not installing
the floor in that area. If you do put it in, you can possibly save
yourself some effort by not drilling all the rivet holes until after the
elevator pulleys, rudder cable pulleys (if used), battery brackets, and
ELT brackets are made. At least some of those brackets will be easier
and stronger if tied into the channels, or easier to install if you
don't have to backdrill and file to fit predrilled rivet holes in the floor.
Joel Jacobs wrote:
Hi guys,
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
WALTER KLATT
Rebel floor
Post by WALTER KLATT » Sat Feb 18, 2012 10:23 am
Interesting how some of the same questions come up 10 years later. I still remember asking someone at MAM about that, too, and basically it was in the builder's choice category. I did finish mine right to the back, but just for looks, no other real reason. I do have my survival gear stuffed back in there to help with w&b.
Date: Tuesday, April 5, 2005 7:56 am
floor
make
channels
installing
after the
brackets, and
easier
you
the floor.
Joel Jacobs wrote:
Hi guys,
to install
elevator>pulleys. My tailcone floor piece ends at the pulleys
but say
the pulleys.
I'll go
wraps)>Is everyone doing it this way? Any reason not to?
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
Joel Jacobs
Rebel floor
Ken,
My thinking exactly. I'm going with a fairly heavy Subaru EJ-22 without
cutting the firewall back, same as you if I remember correctly and that's
why I want to put the batteries (two odyssey pc-680s) back there. I already
have the Scott 3200 and steel trailer spring. I'm planning to drill the
channels but not rivet until I make the brackets so they will pickup the
same holes through the channels. I'll probably also use 3/16 rivets for the
battery mounts as I have visions of them busting loose in a crash and
smacking me in the back of the head. That would be a "BAD thing" (TM)!
Joel
Sent: Tuesday, April 05, 2005 10:56 AM
floor.
Joel Jacobs wrote:
Hi guys,
install
elevator
pulleys.
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
