At 11:27 AM 2/9/2005 -0500, you wrote:
[quote]
Wow !! You
build time was Re: Rebel - 912 powered Empty Weight
Thanks for the suggestions, Drew ! We
[quote]
It depends, there will be two classes of sport plane, experimental and
factory built... so yes, if you are registering experimental and want a
repairman's certificate. If you don't want the repairman's certificate,
then no.
Sent: Thursday, February 10, 2005 4:02 PM
Subject: Re: build time was Re: Rebel - 912 powered Empty Weight
[quote][quote]
then no.
[quote][quote]
OK thanks Mike Since it doesn't directly affect us in Canada I haven't paid
close attention to the rules.
At 04:11 PM 2/10/2005 -0900, you wrote:
[quote]It depends, there will be two classes of sport plane, experimental and
then no.
[quote][quote]
then no.
[quote][quote]
