Float pumps
Ryan Mowat
Float pumps
Post by Ryan Mowat » Sat Feb 18, 2012 10:05 am
Does any one have a good lead on a drill attachment for a float pump?
I'd like to find a motorized version of this plastic work horse that is
wearing me out. It is only a problem if I leave the plane in the lake
for a few days - but it sure would be nice to have a faster easier
system
Ryan Mowat
Float pumps
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:05 am
Montana's don't leak do they??!?!
Sent: Thursday, January 27, 2005 4:07 PM
Subject: Float pumps
system
Ryan Mowat
RJBWoodman
Float pumps
Post by RJBWoodman » Sat Feb 18, 2012 10:05 am
Aerocet fiberglass ( no rivits....no leaks )
just kidding. I couldn't help it.
Randy Bowers
Moose 130
Scott Aldrich
Float pumps
Post by Scott Aldrich » Sat Feb 18, 2012 10:05 am
Randy, How close are you guys to "leak testing" those fancy floats? I
suspect your water is solid right now too.
Scott
Moose 174
RJBWoodman@aol.com
Sent: Thursday, January 27, 2005 2:18 PM
Subject: Re: Float pumps
Randy Bowers
Moose 130
Float pumps
Is the hull comprimised anywhere for main gear attachment/activation etc??
Give it time...the water will find a way in! :o)) or :o((
Sent: Thursday, January 27, 2005 4:18 PM
Randy Bowers
Moose 130
RJBWoodman
Float pumps
The airplane should see some flight testing by early April. Water testing won't be till the ice goes out in May. Getting closer every day.
british thunder
Float pumps
Post by british thunder » Sat Feb 18, 2012 10:06 am
the pump that works best for me was a shop vac. If you have the power there
for the drill anyway. my shop vac has the drain in the bottom so I don't
even have to dump it out,
it will suck 10 gal. of water in 25 seconds. It's great for getting the
sand and dirt out of the inside too.
Cecil
014R
Sent: Thursday, January 27, 2005 3:07 PM
system
Ryan Mowat
LisaFly99
Float pumps
Post by LisaFly99 » Sat Feb 18, 2012 10:06 am
In a message dated 2/1/2005 7:31:39 AM Central Standard Time,
britishthunder@sympatico.ca writes:
RYAN
Sears sells the drill operated pumps. I've used them for water and diesel
fuel. About $12USD
PDSmith
Ryan Mowat
Float pumps
Post by Ryan Mowat » Sat Feb 18, 2012 10:06 am
Thanks for the float pump ideas!
mike.davis
Float pumps
Post by mike.davis » Sat Feb 18, 2012 10:06 am
I just ran into a light weight portable item that might be suitable as a
float pump. I bought a battery powered kerosene pump for $10. It's long and
skinny, designed to fit through the opening of a 5 gal can of kerosene and
reach the bottom. Not terribly fast, probably a couple of gallons a minute.
I can take a pic if anyones interested.
On 2/1/2005 5:30 PM, REBEL-BUILDERS@DCSOL.COM wrote to MIKE DAVIS:
-> the pump that works best for me was a shop vac. If you have the power there
-> for the drill anyway. my shop vac has the drain in the bottom so I don't
-> even have to dump it out,
-> it will suck 10 gal. of water in 25 seconds. It's great for getting the
-> sand and dirt out of the inside too.
-> Cecil
-> 014R
-> From: "Ryan Mowat" <RMowat@forge-industrial.com>
-> Sent: Thursday, January 27, 2005 3:07 PM
-> Subject: Float pumps
-> > Does any one have a good lead on a drill attachment for a float pump?
-> > I'd like to find a motorized version of this plastic work horse that is
-> > wearing me out. It is only a problem if I leave the plane in the lake
-> > for a few days - but it sure would be nice to have a faster easier
-> > system
-> > Ryan Mowat
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
-> List archives located at: https://www.dcsol.com/login?mode=HTML
-> Subscription services located at:
-> https://www.dcsol.com/public/code/html-subscribe.htm
WALTER KLATT
Float pumps
Post by WALTER KLATT » Sat Feb 18, 2012 10:06 am
Can this pump be used to pump gasoline? When I am out at the lake in the summer, I usually have 5 or 6 cans of gas on hand for the boats, or my plane if I have been giving too many rides. But to get fuel into the wing of a docked floatplane isn't always that easy. What I use today is a little hand pump that goes into my gas can on the dock, and pushes the fuel up to the wing. It works, but is slow and cumbersome. If there is a cheap electrical one, I might be interested.
For the float compartments, I just use a small lightweight hand pump that works fine for me. Two quick pumps on each hole just to ensure no leaks, is all that I need, usually. An electrical one wouldn't help me there. I sometimes get a few cupfuls out of the front compartments after being in rough water, as I still haven't sealed off my front wheel well hydraulic hose grommets, but that's it.
Date: Tuesday, February 1, 2005 10:36 am
suitable as a
It's long and
kerosene and
a minute.
power there
so I don't
getting the
-> Cecil
-> 014R
float pump?
horse that is
the lake
easier-> > system
-> > Ryan Mowat
mike.davis
Float pumps
Sorry, not for gasoline... big warning on the package. Have you looked at a
12v faucett pump?
195SR
On 2/1/2005 10:00 AM, REBEL-BUILDERS@DCSOL.COM wrote to MIKE DAVIS:
-> Can this pump be used to pump gasoline? When I am out at the lake in the
-> For the float compartments, I just use a small lightweight hand pump that
-> Walter
-> From: mike.davis@dcsol.com
-> Date: Tuesday, February 1, 2005 10:36 am
-> Subject: Re: Float pumps
-> > I just ran into a light weight portable item that might be
-> > suitable as a
-> > float pump. I bought a battery powered kerosene pump for $10.
-> > It's long and
-> > skinny, designed to fit through the opening of a 5 gal can of
-> > kerosene and
-> > reach the bottom. Not terribly fast, probably a couple of gallons
-> > a minute.
-> > I can take a pic if anyones interested.
-> > Mike
-> > On 2/1/2005 5:30 PM, REBEL-BUILDERS@DCSOL.COM wrote to MIKE DAVIS:
-> > -> the pump that works best for me was a shop vac. If you have the
-> > power there
-> > -> for the drill anyway. my shop vac has the drain in the bottom
-> > so I don't
-> > -> even have to dump it out,
-> > -> it will suck 10 gal. of water in 25 seconds. It's great for
-> > getting the
-> > -> sand and dirt out of the inside too.
-> > -> Cecil
-> > -> 014R
-> > -> ----- Original Message -----
-> > -> From: "Ryan Mowat" <RMowat@forge-industrial.com>
-> > -> To: <rebel-builders@dcsol.com>
-> > -> Sent: Thursday, January 27, 2005 3:07 PM
-> > -> Subject: Float pumps
-> > -> > Does any one have a good lead on a drill attachment for a
-> > float pump?
-> > -> > I'd like to find a motorized version of this plastic work
-> > horse that is
-> > -> > wearing me out. It is only a problem if I leave the plane in
-> > the lake
-> > -> > for a few days - but it sure would be nice to have a faster
-> > easier-> > system
-> > -> > Ryan Mowat
-> > -> > List archives located at: https://www.dcsol.com/login?mode=HTML
-> > -> > username "rebel" password "builder"
-> > -> > Subscription services located at:
-> > -> > https://www.dcsol.com/public/code/html-subscribe.htm
-> > -> > List administrator: mike.davis@dcsol.com
-> > -> List archives located at: https://www.dcsol.com/login?mode=HTML
-> > -> username "rebel" password "builder"
-> > -> Subscription services located at:
-> > -> https://www.dcsol.com/public/code/html-subscribe.htm
-> > -> List administrator: mike.davis@dcsol.com
Float pumps
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:06 am
Now there's an idea Mike.....put a facet pump in each float... with an
intake hose curled up inside..a line up the front mounting strut...in thru
the cabin and tee'd into the fuel line with a check valve. Set gas cans on
float, stick intake hose in and pump away! Might need to hand prop when
you're done though...since the battery will be dead by then. Also remember
there's probably air in the gascolator now!
Sent: Tuesday, February 01, 2005 2:16 PM
12v faucett pump?
195SR
plane
hand
that
is
hose
-> Walter
-> > suitable as a
-> > It's long and
-> > kerosene and
-> > a minute.
-> > Mike
-> > power there
-> > so I don't
-> > getting the
-> > -> Cecil
-> > -> 014R
-> > float pump?
-> > horse that is
-> > the lake
WALTER KLATT
Float pumps
No, but it's a thought. The ones I know are about 30 gph which would take about 15 minutes per gas can, so probably not fast enough for what I would want. I think my hand pump is faster than that. I have not looked for an electric one yet, but maybe there are some, at a reasonable cost that would work.
Date: Tuesday, February 1, 2005 11:16 am
looked at a
12v faucett pump?
195SR
lake in the
or my plane
wing of a
little hand
to the
electrical
pump that
leaks, is
there. I
being in
hydraulic hose
-> Walter
-> > suitable as a
$10.
-> > It's long and
-> > kerosene and
gallons
-> > a minute.
-> > Mike
DAVIS:-> >
have the
-> > power there
bottom
-> > so I don't
for
-> > getting the
-> > -> Cecil
-> > -> 014R
-> > float pump?
work
-> > horse that is
plane in
-> > the lake
faster
https://www.dcsol.com/login?mode=HTML-> > -> > username "rebel"
password "builder"
https://www.dcsol.com/login?mode=HTML-> > -> username "rebel"
password "builder"
Mike Davis
Float pumps
Post by Mike Davis » Sat Feb 18, 2012 10:06 am
I've seen a lot of folks use these small pumps with model airplanes to pump
from their gas can into the airplane... most use the little 14 amp batteries
and can go a month between charges flying every weekend. They are also
common on ultralight aircraft to pump from a seat mounted tank to the main
tank... most 2 stroke lighting coils are only 80 - 100 watts, and they
handle them just fine.
Sent: Tuesday, February 01, 2005 11:14 AM
at
12v faucett pump?
195SR
plane
hand
electrical
that
is
hose
-> Walter
-> > suitable as a
-> > It's long and
-> > kerosene and
-> > a minute.
-> > Mike
-> > power there
-> > so I don't
-> > getting the
-> > -> Cecil
-> > -> 014R
-> > float pump?
-> > horse that is
-> > the lake
