moose rudder trim??
Warren & Marg Montgomery
moose rudder trim??
Post by Warren & Marg Montgomery » Sat Feb 18, 2012 9:50 am
East or West? Correalis or left foot forward??
With the M14s reverse rotation I hinged my trim so it would close the
gap when used.
Left foot, left rudder, right trim. So I recall it's hinged on the left
side?
Hope I calculated it correct??
Warren
Reed Britt Civ OO-ALC/MADE wrote:
Brad - Are you planning on flying in the Northern Hemisphere or the Southern
Hemisphere?
Actually a good question - I didn't even think about it - I too am going to
run a v8 - I think the different PSRU's might spin different directions but
I haven't worried about it yet - I did think about a gap seal on the super
large elevator trim -
Britt SR194
Nielsenbe@aol.com
Sent: Monday, December 13, 2004 1:26 PM
Subject: Re: moose rudder trim??
The other question is what side the trim tab should hinge on. I am planning
on a V-8 installation as of now. With so many other people ahead of my you
guys will have most of the bugs worked out.........thanks
Brad
larry173
moose rudder trim??
Post by larry173 » Sat Feb 18, 2012 9:54 am
Yes they do. I am told that it has heavier gears that the air boat stinger
and the Predator. They also supposed to be modifying it so you can use a
hydraulic prop. Don't know if it is done yet.
From: "Reed Britt Civ OO-ALC/MADE" <Britt.REED@HILL.af.mil>
Sent: Tuesday, December 14, 2004 8:46 AM
Subject: RE: moose rudder trim??
That is interesting - I didn't know that team 38 also uses the Stinger.
larry173
Sent: Monday, December 13, 2004 2:27 PM
All the chain and belts drive are CW , all 3 gear drives are CW, 2 gear
drives (Predators and Team 38 uses a Stinger drive) and they are CCW
Sent: Monday, December 13, 2004 4:00 PM
Southern
Hemisphere?
but
super
Britt SR194
Nielsenbe@aol.com
planning
you
Brad
