Props/O-320
Props/O-320
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:39 pm
Your following message has been delivered to the 133 members of
the list murphy-rebel@dcsol.com at 10:19:47 on 10 Dec 1999.
Ryan, The only person I know, personally, that is running a Prince "P" tip
on a Lycoming is Keith Weston. He is President of the Collingwood Ontario
R.A.A. Chapter. To the best of my knowledge he is quite happy with the prop.
(as he has flown it for some years now on a Zenith) I don't have an e-mail
for him but his phone number is 705-444-1422 if you want to get his honest
opinion! Are you sure you want to go 160 H.P. and not have them build it as
150?? The 160 H.P. is just a diffferent set of pistons that raise
compression, stresses, Octane of fuel required (if you plan to fly floats,
100LL is hard to find at Marina's). etc., but it shouldn't raise the price
and if they are question it!
To: Murphy-rebel@dcsol.com <Murphy-rebel@dcsol.com>
Date: Friday, December 10, 1999 9:25 AM
Subject: Props/O-320
All,
We just ordered our engine (O-320, 160hp) from Aerosport power up in
Kamloops. I have heard nothing but good things about them. Anyway, with
all this talk about weight we are considering putting a wood/composit prop
on such as a Prince "P-tip". Has anyone put a Prince or similar prop on a
Rebel? Seems to save alot of weight and $$$$. Wood also handles harmonics
better than metal (i.e. Canard folks, long ez, cozy....etc). Just curious.
BB&R Amendala
Rebel 669
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
Ryan Amendala
Props/O-320
Post by Ryan Amendala » Fri Feb 17, 2012 5:39 pm
All,
BB&R Amendala
Rebel 669
Props/O-320
Post by Bob Patterson » Fri Feb 17, 2012 5:39 pm
There have been some problems with the Warp Drive composite props on
the 160 HP. - no problems on the 150 HP.
The only consideration with a wood prop is that you should make up
a cover for it - that lets air circulate, but blocks sunlight. The sun
will destroy the varnish and let moisture into the wood. We have replaced
several wood props before we went to a cover. I think this would also be
a GOOD IDEA for composite props - all composite gliders are painted white,
and kept out of the sun when possible ....
When parking your aircraft, with a wood prop, always keep the blades
horizontal. If they are vertical, water will run down to the lower blade
and be absorbed. This will throw the balance of the prop off, over time !!
....bobp
-----------------------------orig.----------------------------------------
At 02:25 PM 12/10/99 GMT, you wrote:
All,
BB&R Amendala
Rebel 669
Props/O-320
Your following message has been delivered to the 135 members of
the list murphy-rebel@dcsol.com at 17:14:18 on 13 Dec 1999.
Ryan, there is nothing else I can recommend for beefing the firewall, that
hasn't already been discussed in the "firewall warping" section of the
archives.
P.S. Didn't realize you were in Washington State and wanted to fly in and
out of the glacier ponds!!! Maybe you need a Supercharged engine so you
always have that 160HP???? Could you fill the floats with helium??? Now
there's an idea!!!!!!!!!
Date: Monday, December 13, 1999 11:24 AM
Subject: Re: Props/O-320
Wayne,
We have contimplated this for a while. We decided on the 160hp to get the
max power available for our Rebel (which we are putting on 1800 amphibs)
with the consideration of stress, fuel consumption..etc. On the long ez we
went with the 150hp for just those reasons, but we will not be flying out
Lakes with tall trees at 9000' with the long ez (although it would be
really
Cool!!). One thing that I did not consider is fuel availability at
Marinas!
Hopefully the amphib will help out here. Thanks for your help. This is
just another reminder of how much there is to learn about float flying!
On a side note, we have done the "beefing up" that MAM recommends for the
O-320 in the plane (channel ran across top 2 engine mounts for the
firewall,
gussets at the door posts..etc). Is there anything we are missing for the
firewall, it still seems very.. strength challenged for a 160hp engine!
Thanks again
BB&R Amendala
Rebel 669, Olympia, WA
Working on the fuse.
----Original Message Follows----
Reply-To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Date: Fri, 10 Dec 1999 10:18:33 -0500
prop.
All,
prop
harmonics
curious.
BB&R Amendala
Rebel 669
Ryan Amendala
Props/O-320
Wayne,
went with the 150hp for just those reasons, but we will not be flying out of
Lakes with tall trees at 9000' with the long ez (although it would be really
Cool!!). One thing that I did not consider is fuel availability at Marinas!
O-320 in the plane (channel ran across top 2 engine mounts for the firewall,
Thanks again
BB&R Amendala
All,
harmonics
curious.
BB&R Amendala
Rebel 669
