mechanical linkage like I do!).
As for your Warp Drive...I found I couldn't even move on skis when I first
mounted mine to the 100HP and kept pitching finer and finer until I got the
static RPM up to 2350 (on a 2600 RPM max engine) With 2350 static I could
still only reach 2550 in cruise full throttle..so eventually took out
another 1/2* of pitch. At 2170 and 2240 RPM I couldn't even get the airplane
to move!
One degree on the 150 HP seems to make about 100 RPM difference. If you are
only getting 2200 I would be temped to take 2 degrees out to start with and
see what happens. What can you get balls to the wall in cruise the way it is
now?
From: "Peter, Juliet, & Wanaao Piascik" <northofsixty@mac.com>
Sent: Thursday, November 18, 2004 1:22 AM
Subject: Re: Skis on a Rebel
Thanks for the replies guys.
There was ice frozen on the bottom of the skis before I left the
airport. I tried to remove this ice with a scraper.
The lake I was landing on had some spots of overflow, but not much.
The wheels are about 1" below the skis.
I have a warp drive prop set at 130. Wayne do you think I should set
100? I am only getting 2200RPM on takeoff.
Another thing I am wonder about are the flaps. With selection of flaps
in the air it doesn't seem to be much down. I am use to a cessna, when
you select 100 flap the flaps are 100. With full flaps on the Rebel
it
looks like I get 50 in the air. I have the MAM handle to a cable.
Peter
On 17-Nov-04, at 11:38 AM, Drew Dalgleish wrote:
At 10:07 AM 11/17/2004 -0700, you wrote:Hi guys:
Just looking for some ideas about ski flying on a Rebel (0-320).
I have my Rebel on penetration skis. I was out yesterday doing some
touch and goes on a lake just out side of Yellowknife, temp -80C. I
almost had the guts to stop but decided not to and aborted the
stopping, it took me about a mile to get her airborne. There is justto
much drag to get a load, 300 Ibs & half fuel, off a lake on
penetration
skis.
Some one recommend I deflate the tire put a piece of metal under the
tire and reinflate the tire to hold the metal in place thus turningHi Peter Was it slushy under the snow? Water overflow on the ice canthe
penetration skis into straight skis.
Who out there operate on skis.
Petermake
it impossible to get off I'm told. No personal experience that way butI
flew my rebel with penetration skis last winter and never had any
problem
getting off the ground. What kind of bottoms do you have? Could therehave
been an ice buildup?
