scott tail wheel mounting
Jones, Michael
Post by Jones, Michael » Sat Feb 18, 2012 12:40 pm
hi all
perhaps some one could suggest what to use to bolt the scott tail wheel to
the steel spring, was planing on an8-16 bolt, but should i use fibre nut or
castle nut ?
thanx
mike#007
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:40 pm
One or the other...otherwise it will just fall off ! :o))
Seriously..mine's never loosened (going into my 10th year) and it's held on
with a fiber nut AN365-8
To: "Rebel-Builders EMIAL (E-mail)" <rebel-builders@dcsol.com>
Sent: Tuesday, November 16, 2004 3:40 PM
Subject: scott tail wheel mounting
hi all
or
castle nut ?
thanx
mike#007
Jones, Michael
hi wayne
thanks for info, any idea what to torque a 365-8 to ??
mike
From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
Sent: Tuesday, November 16, 2004 4:25 PM
Subject: Re: scott tail wheel mounting
hi all
or
castle nut ?
thanx
mike#007
Post by Drew Dalgleish » Sat Feb 18, 2012 12:40 pm
Hi Mike
My german instructor from drager breathing apparatus had 2 torque values
shnug and gut'n'tight ;)
If that's a 3/8" fine thread bolt torque it to 160-190inch pounds. If it's
3/16" I think you need something stronger but the torque is 20-25"lbs.
mike
hi all
or
castle nut ?
thanx
mike#007
Jones, Michael
hi drew
its an8 bolt, 1/2 inch for scott tail wheel mounting
From: Drew Dalgleish [mailto:drewjan@cabletv.on.ca]
Sent: Wednesday, November 17, 2004 10:31 AM
Subject: RE: scott tail wheel mounting
Hi Mike
mike
hi all
or
castle nut ?
thanx
mike#007
As tight as you can get it with a standard issue wrench in your hand!
480 to 690 in lbs (40 to 58 ft-lbs)
Sent: Wednesday, November 17, 2004 7:03 AM
hi wayne
mike
on
hi all
or
castle nut ?
thanx
mike#007
