Moose tailwheel stinger
A friend of mine has a "surplus" 10" tailwheel assembly off of a 185 (or
a Scott tailwheel). The problem is that I believe (haven't checked it
yet myself) it is for a 1 1/16" stinger whereas my Moose has a 1"
stinger.
Does anyone know what is involved in changing my stinger to the larger
size (major disassembly & rework or a relatively straight-forward
process)?
Following recent discussions on this list regarding problems with the
MAM tailwheel, I'd like to switch mine.
Ted
stinger.
process)?
Ted
It would be a good amount of work to change the stinger bracket size. What
about just putting a steel sleeve over the end?
Scott
Waltman
Sent: Thursday, November 11, 2004 1:09 PM
To: Murphy List
Subject: Moose tailwheel stinger
stinger.
process)?
Ted
Scott
Waltman
To: Murphy List
stinger.
process)?
Ted
I don't know Scott...I'd have to go out and open up the marine container to
have a look at my Moose...but don't see reaming a 1/16th out of that steel
spring retainer ball (at the tail post) and relieving the sides of the
Cessna Stinger slightly (if even needed) to bolt in on the multi hole
bracket. Cessna's got increased in size as they used to be 7/8 or so and
Broke quite often.
Is the MAM one 1" or 7/8" ??
Sent: Friday, November 12, 2004 12:17 PM
Subject: RE: Moose tailwheel stinger
Broke quite often.
WhatIt would be a good amount of work to change the stinger bracket size.
Scott
Waltman
To: Murphy List
stinger.
process)?
Ted
I'm sure the MAM stinger is 1".
Ted
Sent: Friday, November 12, 2004 1:39 PM
Subject: Re: Moose tailwheel stinger
to have a look at my Moose...but don't see reaming a 1/16th out of that
steel spring retainer ball (at the tail post) and relieving the sides of
the Cessna Stinger slightly (if even needed) to bolt in on the multi
hole bracket. Cessna's got increased in size as they used to be 7/8 or
so and Broke quite often.
Ted
Scott
Ted Waltman
To: Murphy List
(or a Scott tailwheel). The problem is that I believe (haven't
checked it yet myself) it is for a 1 1/16" stinger whereas my Moose
has a 1" stinger.
process)?
Ted
Then I can't see reaming the tail spring retainer "ball" being reamed 1/16th
being a problem IMHO.
Sent: Friday, November 12, 2004 4:27 PM
Ted
WhatIt would be a good amount of work to change the stinger bracket size.about just putting a steel sleeve over the end?
Scott
Ted Waltman
To: Murphy List
has a 1" stinger.
Does anyone know what is involved in changing my stinger to the largersize (major disassembly & rework or a relatively straight-forward
process)?
Ted
I have read of problems with the Rebel tail wheel from MAM. Two questions. 1) has the moose/2500 tail wheel presented a problem, demonstrated issues, etc. 2) Is there reason to believe it will?
Rick Muller
SR70
Rick Muller
SR70
To:
Ted
To:
Scott
Ted Waltman
To: Murphy List
has a 1" stinger.
process)?
Ted
Looks like a pretty stout casting to me...but have no field experience with
it. Wayne
Sent: Friday, November 12, 2004 5:43 PM
it. Wayne
questions. 1) has the moose/2500 tail wheel presented a problem,I have read of problems with the Rebel tail wheel from MAM. Two
1/16thRick Muller
SR70
containerbeing a problem IMHO.
To:
Ted
thatto have a look at my Moose...but don't see reaming a 1/16th out of
ofsteel spring retainer ball (at the tail post) and relieving the sides
size.the Cessna Stinger slightly (if even needed) to bolt in on the multi
To:
OfWhat
larger
Ted
A 10" Scott tailwheel would work good but keep in mind the tailsprings are
totally different as the Cessna is tapered and bent. The Cessna sizes were
7/8, 15/16, 1, and 1 1/8. I do not believe there was ever a 1 1/16" spring.
The nuckle at the back of your tailcone would be a tough one to drill out
and possibly dificult to remove depending how it was installed. Also hard to
adapt the 1" tailspring to a bigger hole in the Scott as it takes a fixture
to hold it in place while drilled. A new 1" casting is around $350 I think.
Another option is the new Alaska Bushwheel tailwheel which has just come
available in a 3400 size but at least $1000. You may not like it on pavement
though. If you shop around you will find a Scott with a 1" hole at a good
price.
Steve Rhodes
Moose 173
Sent: Friday, November 12, 2004 08:17
price.
Steve Rhodes
Moose 173
What
Scott
Waltman
To: Murphy List
stinger.
process)?
Ted
