Aileron control horn fixed?
Mike Davis
Post by Mike Davis » Fri Feb 17, 2012 7:21 pm
Received: from MMoreho699@aol.com
by imo18.mx.aol.com (IMOv14.1) id GVPDa12991;
Wed, 22 Apr 1998 19:31:47 -0400 (EDT)
Message-ID: <442a39d5.353e7de5@aol.com>
Date: Wed, 22 Apr 1998 19:31:47 EDT
To: murphy-rebel@dcsol.com, murtech@murphyair.com
Mime-Version: 1.0
Subject: Aileron control horn fixed?
X-Mailer: AOL 3.0 for Mac sub 78
Hello!
Concerning the Rebel that I had a rivet head sticking out after deploying on
the root end of the control horn: I drilled it out and the one that it was
butting up against at 90 degrees to it. I was able to get the remaining two
rivets flush, but now I have the inside ends of three rivets rolling around
in
my sealed torque tube. The sound of this rolling around forever will remind
me
of the graceful way I hurdled this obstacle. But will these small pieces
ever
cause my silver bird to fall from the sky?
Dan
Mike Davis
Received: from albedo.net (ppp119.albedo.net [206.51.22.138]) by
juliet.albedo.net (8.8.3/8.6.9) with ESMTP id TAA27402 for
<murphy-rebel@dcsol.com>; Wed, 22 Apr 1998 19:54:05 -0400
Message-ID: <353E8287.31248055@albedo.net>
Date: Wed, 22 Apr 1998 19:51:35 -0400
X-Mailer: Mozilla 4.04 [en] (Win95; I)
MIME-Version: 1.0
Subject: Re: Aileron control horn fixed?
References: <442a39d5.353e7de5@aol.com>
Dan
Are the rivet mandrels magnetic? Could you get them out through the 1/4 inch
hole in the center of the end plug?
Another option might be to glue them to the tube so they don't rattle
around, if
having them loose bothers you.
MMoreho699 wrote:
Hello!
on
was
two
around in
remind me
ever
Dan
Mike Davis
Received: from d.james (ba1p10.planeteer.com [204.50.144.43])
by toronto.planeteer.com (8.8.7/8.8.7) with ESMTP id WAA15623;
Wed, 22 Apr 1998 22:28:55 -0400 (EDT)
Message-ID: <353EA809.A40C9A69@planeteer.com>
Date: Wed, 22 Apr 1998 22:31:38 -0400
X-Mailer: Mozilla 4.01 [en] (Win95; I)
MIME-Version: 1.0
CC: murtech@murphyair.com
X-Priority: 3 (Normal)
X-Corel-MessageType: EMail
MMoreho699 wrote:
Hello!
deploying on
it was
remaining two
around in
remind me
pieces ever
Dan
At one of the Southern Ontario Rebel builders meeting one of ex
Dehavilland (Spelling?) workers told a story about a set of cleco pliers
dropped into the tail section of a Dash 8 that were totally inaccessable
yet rattled around. They poured in zinc chromate and let it set up ans
then poured more until there was no more rattle. This could work for
you.
David James
Rebel 228
Mike Davis
Received: from tim - 153.35.237.223 by email.msn.com with Microsoft SMTPSVC;
Thu, 23 Apr 1998 11:36:56 -0700
Received: by localhost with Microsoft MAPI; Thu, 23 Apr 1998 11:33:50 -0700
Message-ID: <01BD6EAB.B013EA00.tlcarter@email.msn.com>
Reply-To: "tlcarter@msn.com" <tlcarter@msn.com>
To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
Subject: RE: Aileron control horn fixed?
Date: Thu, 23 Apr 1998 09:52:30 -0700
X-Mailer: Microsoft Internet E-mail/MAPI - 8.0.0.4211
MIME-Version: 1.0
Return-Path: tlcarter@email.msn.com
Hi gang:
The rivet mandrels are magnetic, the SS rivet sleeve itself is not.
I had a similar experience, so took a coathanger wire and put a small dab
of sticky glue on the tip, reached in thru the 1/4" center hole, and got
the maverick pieces to stick to my 'stick'. I got them out.
Reply To: murphy-rebel@dcsol.com
Sent: Wednesday, April 22, 1998 4:51 PM
To: (Murphy Rebel)
Dan
inch
around, if
MMoreho699 wrote:
Hello!
on
was
two
around in
remind me
ever
Dan
Mike Davis
by imo18.mx.aol.com (IMOv14.1) id GHAOa12983
for <murphy-rebel@dcsol.com>; Sat, 25 Apr 1998 01:21:23 -0400 (EDT)
Message-ID: <61eac0e4.354172d5@aol.com>
Date: Sat, 25 Apr 1998 01:21:23 EDT
Mime-Version: 1.0
Subject: Re: RE: Aileron control horn fixed?
Thanks for all the feedback!
Here's what I did:
I tried the glue on the stick and still couldn't get much. I also tried a
shop
vac with no luck. So I drilled a larger hole in the center of the horn,
~1/2".
This still gave me plenty of edge distance for the rivets. It also allowed
me
to see where the buggers were. I nabbed them then with the glue stick.
Have a good weekend,
Dan
Mike Davis
Received: from chucks.gte.net (1Cust217.tnt3.krk1.da.uu.net
[153.37.255.217])
by smtp2.mailsrvcs.net with SMTP id KAA12755
for <murphy-rebel@dcsol.com>; Sat, 25 Apr 1998 10:10:24 -0500 (CDT)
Message-ID: <001901bd705b$19354be0$d9ff2599@chucks.gte.net>
Date: Sat, 25 Apr 1998 08:01:58 -0700
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.2106.4
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.2106.4
I think you are ok if you drilled the larger hole on the outboard end of the
tube. I think the inboard end hole is used for alignment and centering of
the matching horn on the fuselage. I guess you could always make the
alignment pin larger if you had to though.
- Chuck -
Date: Friday, April 24, 1998 10:31 PM
Here's what I did:
shop
~1/2".
me
Dan
