prop and oil temps
prop and oil temps
Just a quick note to report the outcome of my changes.
I tried a friends 76-52 prop (way too fine) then repitched my 76-56 to
54" ----Works great.
Moved the oil-cooler from the lower left fire-wall to the left rear
engine baffle ---------Temps are now in the 195-210F range-----Perfect.
The 52" prop dropped my 75% power cruise to 80kts and had the 0-320 near
red-line on take-off, the 54" put me at 2500+ on take-off and 90kts
cruise power.
While pre-flighting after the Orillia float plane fly-in I found a
slight leak from my oil-cooler spraying onto the fire-wall and pulled it
off for a trip to the oil-cooler shop in Winnipeg,It was not repairable
nor was the second cooler we sent from a wrecked C-150 so I had to buy
an overhauled cooler and got it back on last Friday. The overhauled one
is not very pretty but it's tagged and has nice new paint on it.
Next chore for me is repairing a leak in an out-board float compartment
at the step, where the gear-hinge bolt goes.
Bob Fisher- It was great to finally get to meet you and see your really
nice Rebel,sorry we did not get to visit you at home but hope to do that
soon.
If anyone happens to be in this area on Saturday Sept.4 we are hosting
a huge bash here at our farm near London Ontario and you are invited to
attend. Pig-roast,band,lots of aviation types!
Regards to all, Angus
cruise power.
soon.
prop and oil temps
Angus, I assume your prop diameters are 74 not 76. If so, your
numbers are bang on with my 74 X 54, with 2500 RPM take-off and
cruise at 90 knots (105 mph). My WOT top speed is about 2720 and
120+ mph. Again, this is with the 150 hp 0320 Rebel amphib.
"Angus McKenzie" <angus@lweb.net> wrote in message
news:006e01c48e98$2dbb7690$7305efd1@Thinkpad...
cruise power.
soon.
prop and oil temps
You are correct,my mistake.
I will have to check and see what my WOT speed and RPM will be.
Angus
Sent: Tuesday, August 31, 2004 8:11 PM
Subject: Re: prop and oil temps
Angus
prop and oil temps
Hi the speed are great,how is it off the water,and what type of prop Sen.,or
McCall.
THANKS
jerry
Sent: Tuesday, August 31, 2004 5:11 PM
McCall.
THANKS
jerry
news:006e01c48e98$2dbb7690$7305efd1@Thinkpad...Just a quick note to report the outcome of my changes.
cruise power.
soon.
prop and oil temps
Hi Jerry
The 74-54 prop is a McCauley Klip-Tip that I bought with my 0-320 engine off
a buddy's 7GCB.So my engine and prop have been partners since 1960.
Sorry I can not say about the water take-off.I am still trying to feel out
the right spot on the floats for best performance. Maybe bobp could step in
here as he and Robin watched Jennifer and I depart from the water at
Orillia.
Regards, Angus
Sent: Wednesday, September 01, 2004 12:40 AM
Orillia.
Regards, Angus
Sen.,orHi the speed are great,how is it off the water,and what type of prop
range-----Perfect.McCall.
THANKS
jerry
nearThe 52" prop dropped my 75% power cruise to 80kts and had the 0-320
itred-line on take-off, the 54" put me at 2500+ on take-off and 90kts
cruise power.
repairableoff for a trip to the oil-cooler shop in Winnipeg,It was not
onenor was the second cooler we sent from a wrecked C-150 so I had to buy
compartmentis not very pretty but it's tagged and has nice new paint on it.
reallyat the step, where the gear-hinge bolt goes.
thatnice Rebel,sorry we did not get to visit you at home but hope to do
hostingsoon.
toa huge bash here at our farm near London Ontario and you are invited
prop and oil temps
THANKS Angus
You know how it goes those high little lakes look to good sometimes
THANKS
jerry
Sent: Wednesday, September 01, 2004 6:24 AM
THANKS
jerry
offHi Jerry
ina buddy's 7GCB.So my engine and prop have been partners since 1960.
tohere as he and Robin watched Jennifer and I depart from the water at
Orillia.
Regards, Angus
Sen.,orHi the speed are great,how is it off the water,and what type of propMcCall.
THANKS
jerry
pulledrange-----Perfect.near
buyitrepairable
onecompartmentreallythathostingto
prop and oil temps
Mine is the Sensenich. I don't have any actual measurements off the water,
and it ranges anywhere from about 10 seconds lightly loaded into a breeze to
upwards of 20 seconds as my load goes up. I can usually get 2 people and a
good load off in 25 seconds or less. Climb solo is 1100, and 800 loaded. Of
course, those numbers drop in hot weather and at higher altitudes.
"Jerry Purdom" <jerrygoneflying@shaw.ca> wrote in message
news:00bb01c48fdd$ce1762c0$34554718@ok.shawcable.net...
THANKS
jerry
cruise power.
hostingsoon.
prop and oil temps
Hi Angus !
Jumping in ! :-) Splash !!!
I didn't time your takeoff, but it was shorter than all of the other
takeoffs we watched - and the climbout was impressive too !! :-)
Hi Jerry
Orillia.
Regards, Angus
Sen.,orHi the speed are great,how is it off the water,and what type of proprange-----Perfect.McCall.
THANKS
jerry
news:006e01c48e98$2dbb7690$7305efd1@Thinkpad...nearitrepairableonecompartmentreallythathostingto
prop and oil temps
the water, and it ranges anywhere from about 10 seconds lightly
loaded into a breeze to upwards of 20 seconds as my load goes
up. I can usually get 2 people and a good load off in 25 seconds
or less. Climb solo is 1100, and 800 loaded. Of course, those
Jerry Purdom
Sent: Tuesday, August 31, 2004 9:40 PM
McCall.
THANKS
jerry
If so, yourAngus, I assume your prop diameters are 74 not 76.take-off andnumbers are bang on with my 74 X 54, with 2500 RPMabout 2720 andcruise at 90 knots (105 mph). My WOT top speed isrepitched my 76-56 to120+ mph. Again, this is with the 150 hp 0320 Rebel amphib.
I tried a friends 76-52 prop (way too fine) thento the left rear54" ----Works great.
Moved the oil-cooler from the lower left fire-wall195-210F range-----Perfect.engine baffle ---------Temps are now in theand had the 0-320 nearThe 52" prop dropped my 75% power cruise to 80ktstake-off and 90ktsred-line on take-off, the 54" put me at 2500+ onfly-in I found acruise power.
While pre-flighting after the Orillia float planefire-wall and pulled itslight leak from my oil-cooler spraying onto theWinnipeg,It was not repairableoff for a trip to the oil-cooler shop inC-150 so I had to buynor was the second cooler we sent from a wreckedFriday. The overhauled onean overhauled cooler and got it back on lastnew paint on it.is not very pretty but it's tagged and has niceout-board float compartmentNext chore for me is repairing a leak in anyou and see your reallyat the step, where the gear-hinge bolt goes.
Bob Fisher- It was great to finally get to meethome but hope to do thatnice Rebel,sorry we did not get to visit you atSept.4 we are hostingsoon.
If anyone happens to be in this area on Saturdayand you are invited toa huge bash here at our farm near London Ontarioattend. Pig-roast,band,lots of aviation types!
