Aileron skin problem
I was stoked yesterday when I got my first aileron all clecoed together and
it actually looks like an airplane part. Today was kind of a downer though.
When I bent over the rear edges of the leading edge skin between the ribs.
I used my homemade edge roller. The 1/4" edge I bent over is pretty wavy. It
didn't"t just roll over nicely like I was hoping. The actual edge that will
touch the fabric is pretty straight, and probably with the the fabric and
tape on there it will look fine, but I will have to look at that ugly
bent-over edge until then, and worse I dread having to butcher 3 more
ailerons like that. Is there a better way? The instructions say to use a
block of wood with a notch in it, so I can't imagine my roller is doing
worse than that. I was thinking about making a mini break out of wood, and
bending the skin removed from the aileron and clamped on the table. It
seems
like the problem is that the spar flange doesn't provide enough support for
bending the skin.
Please help.
Thanks.
Jesse Jenks
seems
bending the skin.
Please help.
Thanks.
Jesse Jenks
Hi Jesse
Sounds like yr stretching the edge. If u use the roller, only use it
several times--- more will elongate the edge so it won't lay flat. Very
common with soft alum with a bit of over-working. Chafe tape and fabric will
hide alot.
Steve W. Rebel 637
Don't just Search. Find! http://search.sympatico.msn.ca/default.aspx The new
MSN Search! Check it out!
hide alot.
Steve W. Rebel 637
_________________________________________________________________From: rebel@dcsol.com
Subject: Aileron skin problem
Date: Thu, 19 Aug 2004 20:25:29 -0800
It
seems
bending the skin.
Please help.
Thanks.
Jesse Jenks
Thanks Steve,
would I do better with the notched wood method? How do most people do this
step?
Get ready for school! Find articles, homework help and more in the Back to
School Guide! http://special.msn.com/network/04backtoschool.armx
step?
_________________________________________________________________From: "steve whitenect" <srwhitenect@hotmail.com>
Subject: RE: Aileron skin problem
Date: Fri, 20 Aug 2004 16:20:08 +0000
Hi Jesse
will
hide alot.
Steve W. Rebel 637
andFrom: rebel@dcsol.com
I was stoked yesterday when I got my first aileron all clecoed togetherthough.it actually looks like an airplane part. Today was kind of a downerribs.When I bent over the rear edges of the leading edge skin between thewillI used my homemade edge roller. The 1/4" edge I bent over is pretty wavy.
It
didn't"t just roll over nicely like I was hoping. The actual edge thatandtouch the fabric is pretty straight, and probably with the the fabric and
worse than that. I was thinking about making a mini break out of wood,forbending the skin removed from the aileron and clamped on the table. It
seems
like the problem is that the spar flange doesn't provide enough support_________________________________________________________________bending the skin.
Please help.
Thanks.
Jesse Jenks
new
Jesse: When I built my Rebel and came to this step, I had two pieces of wood
screwed together about 1" shorter on each side then the rib spacing. Clamp
on the skin, and very gently flex down until you get the required amount of
bend. I had great success with nice straight bends and edges. Bob J Rebel
652.
652.
Thank you Bob,
I was thinking of something like that too. I wish I would have tried it. Oh
well, I will do it for the other 3.
Check out Election 2004 for up-to-date election news, plus voter tools and
more! http://special.msn.com/msn/election2004.armx
_________________________________________________________________From: "Robert and Olga" <rjohnson18@cogeco.ca>
Subject: Re: Aileron skin problem
Date: Fri, 20 Aug 2004 19:37:37 -0400
wood
652.
Hi Jesse
Just use the roller but don't overwork it. Several complete passes shud do
it slightly increasing the angle on each pass.
Steve
Take charge with a pop-up guard built on patented Microsoft
Steve
_________________________________________________________________From: "Jesse Jenks" <jessejenks@hotmail.com>
Date: Fri, 20 Aug 2004 13:43:01 -0700
Thanks Steve,
step?
wavy.From: "steve whitenect" <srwhitenect@hotmail.com>
Hi Jesse
will
hide alot.
Steve W. Rebel 637
I was stoked yesterday when I got my first aileron all clecoed togetherthough.it actually looks like an airplane part. Today was kind of a downerribs.When I bent over the rear edges of the leading edge skin between theI used my homemade edge roller. The 1/4" edge I bent over is prettyandwillIt
didn't"t just roll over nicely like I was hoping. The actual edge thattouch the fabric is pretty straight, and probably with the the fabricatape on there it will look fine, but I will have to look at that ugly
ailerons like that. Is there a better way? The instructions say to use_________________________________________________________________andblock of wood with a notch in it, so I can't imagine my roller is doing
seems
Please help.
Thanks.
Jesse Jenks
new
Steve,
I am going to try clamping between blocks first. I'm scared of the roller
now. I'll tell you how it goes.
Date: Mon, 23 Aug 2004 16:48:11 +0000
Hi Jesse
Steve
thisFrom: "Jesse Jenks" <jessejenks@hotmail.com>
Thanks Steve,
would I do better with the notched wood method? How do most people dotogetherstep?
Hi Jesse
will
hide alot.
Steve W. Rebel 637
thatwavy.and though. ribs.useandwilldoingawood,ItandsupportThefor _________________________________________________________________
Don't just Search. Find! http://search.sympatico.msn.ca/default.aspxto_________________________________________________________________new
Get ready for school! Find articles, homework help and more in the BackSchool Guide! http://special.msn.com/network/04backtoschool.armx
Thanks Bob,
I used this method on my second aileron and it worked great. I got a nice
straight bend line. I tried clamping the wood together with a bunch of Quick
Clamps, but it wasn't tight enough to get a crisp bend, so I screwed it
together which did hold it.
By the time I get to aileron #4 I should have it all figured out!
FREE pop-up blocking with the new MSN Toolbar
wood
652.
