pitot tubes
David Qualley
pitot tubes
Post by David Qualley » Fri Feb 17, 2012 5:57 pm
Hi Mike..
I have a Pitot Tube up for auction on Ebay right now..
http://cgi.ebay.com/aw-cgi/eBayISAPI.dl ... =422050620
For anyone else who's interested I also have some 3/16" nutplates..
http://cgi.ebay.com/aw-cgi/eBayISAPI.dl ... =422722167
#057SR
"Jones, Mike" wrote:
Does any one knoe of sources of pitot tubes other than murphy and aircraft
spruce, maybe used ones ???
Mike#007
EOM
Jones, Mike
pitot tubes
Post by Jones, Mike » Fri Feb 17, 2012 5:57 pm
Mike#007
EOM
pitot tubes
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:57 pm
Your following message has been delivered to the 155 members of
the list murphy-rebel@dcsol.com at 18:05:12 on 30 Aug 2000.
Mike, if you are not worried about having a heated one, you can easily make
one for about $5. On Howards we installed a stainless steel tube (5/16"
brake line) at the2nd last rib of the wing. Drilled a hole thru leading edge
and front spar for tube, with the tube being affixed to a 90 degree bulkhead
fitting mounted to the centre web of the leading edge rib. Tube sticks out
of the L.Edge about a foot and has automatic pitot cover on it (like you
find on a V.F.R. Cessna 150). The little pitot cover is the most expensive
part of the whole installation! Works great and it is out in nice clean
undisturbed air and not effected by prop blast. Was done as a fluke as
Howard never installed a pitot line prior to closing his wings (He was used
to Zenair's methods of fabrication I guess!). We ran the pitot line through
the small "D" in front of the front spar(smeared RTV sealant on it here and
there so it would stick and not bounce around) and then it just turns 180
degrees (inside the wing tip) to go into the leading edge rib area and
attaches to the tube bulkhead fitting.
The other nice thing about it being that far out on the wing is that even on
wheels the tube is high enough that most people do not bump into it!
Blue skies and tailwinds,
Sent: Wednesday, August 30, 2000 3:50 PM
Subject: pitot tubes
Mike#007
EOM
confidential
rebel
pitot tubes
Post by rebel » Sat Feb 18, 2012 9:20 am
hi all
i have got an old shark fin kollsman pitot tube, any one know how to mount
them, pictures would be nice
mike #007
Dick Shotwell
pitot tubes
Post by Dick Shotwell » Sat Feb 18, 2012 9:20 am
Mike,
We have one of these on our Moose. I would be glad to send you a picture
when I return next weekend. Let me know.
Dick
Moose 096
Sent: Monday, July 26, 2004 6:53 AM
hi all
mike #007
Jones, Michael
pitot tubes
Post by Jones, Michael » Sat Feb 18, 2012 9:20 am
that would be great, hoepfully you can show how is mounted, thanx
mike#007
Sent: Monday, July 26, 2004 12:09 PM
Subject: Re: pitot tubes
Mike,
Dick
Moose 096
hi all
mike #007
