Primer Fittings
Primer Fittings
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:05 am
Yes Clay, they are just soldered on. No different than plumbing a house with
copper pipe!
Sent: Monday, March 15, 2004 8:52 PM
Subject: Re: Primer Fittings
Thanks Wayne, before ordering the proper fittings from ACS (too bad you
don't have any) I'll try the compression fittings as you suggested. Tell
me
... are those AN cones soldered to the tubing before tightened into place?
Would they solder OK to the copper tubing?
Clay
Sent: Monday, March 15, 2004 11:58 AM
Clay, had a look through my stuff and unfortunately don't have any
AN800/805-2's! 100's of -3's but no -2's :o( !
I had a really close look at the old spray primer nozzles and their tube
seating area and a matching nut versus a new $1.99 CTC brass compression
tube to npt nipple and the sealing surfaces (and mating thread) are
close
enough that if you bought a pack of sleeves and nuts (or any fitting
assembly to steal same from) pretty sure they would do the trick for you
hold everything tightly and leak free.
Sent: Monday, March 15, 2004 10:09 AM
Clay, if you have the original spray style nozzles you most likely
need
cone and matching nut since the sealing surface shape is not the same
as
compression fittings face. You can just use an 1/8" NPT compression
nipple
for the primers, but if you already have the proper spray style (with
little tube coming out of them) all the better and you should match up
connection properly.
Pretty sure I have a box of the AN800's but not sure about the nuts.
Will
have a look shortly and let you know.
Sent: Monday, March 15, 2004 12:11 PM
Subject: Primer Fittings
my
these
cone,
union
Rebel599r
Primer Fittings
Post by Rebel599r » Sat Feb 18, 2012 9:05 am
dont know a lot about plumbing as this is my first time building.and i
haven't done any thing fire wall forwerd yet. but i would be afraid of a solder
joint incace of a fire it may come apart!
Primer Fittings
tube to npt nipple and the sealing surfaces (and mating thread) are close
assembly to steal same from) pretty sure they would do the trick for you and
Clay, if you have the original spray style nozzles you most likely need
cone and matching nut since the sealing surface shape is not the same as a
compression fittings face. You can just use an 1/8" NPT compression nipple
for the primers, but if you already have the proper spray style (with the
little tube coming out of them) all the better and you should match up the
Pretty sure I have a box of the AN800's but not sure about the nuts. Will
Hi Guys,
I'm trying to hook-up my 1/8 copper line to the discharge nipples on my
0320. I believe I need a 5/16-32 thread nut and sleeve to go with these
nipples. Should I order the solder-on type fittings ( AN800 union cone,
AN805-2 union nut)? Any problem soldering the copper tubing to this
union
cone? Is there a compression fitting available for that nipple?
Thanks again,
Clay
Clay Smith
Primer Fittings
Post by Clay Smith » Sat Feb 18, 2012 9:05 am
Hi Guys,
AN805-2 union nut)? Any problem soldering the copper tubing to this union
Thanks again,
Clay
Primer Fittings
Clay, if you have the original spray style nozzles you most likely need the
Hi Guys,
Thanks again,
Clay
Clay Smith
Primer Fittings
don't have any) I'll try the compression fittings as you suggested. Tell me
Clay
nipple
Will
Hi Guys,
my
these
cone,
union
Thanks again,
Clay
Primer Fittings
It's the way they've been done for a 100 years! Do you have any other way to
put an AN800 end sleeve onto a copper tube? They're not flare fittings and
the only option is to push the tube into the AN800 end and solder in place.
In reality compression fittings aren't to be used on an airplane, but we
sneak the odd one in here and there!
Besides I can't see the fire getting that severe to cause the solder to come
loose/melt and also consider the fact that this fitting is screwed into the
fire source that makes the engine run and the primer lines don't catch
fire/melt. IF the fire is really that hot, a primer line coming loose is
your least worry!
Sent: Monday, March 15, 2004 9:28 PM
solder
