Tank Sealing, was: Re: Torque Tube
Thanks for the support Dave
I have been collecting a LOT of instructions on tank sealing, including
yours. Most probably next thursday will be the D day! I will let you know
the results.
Unfortunatelly I cannot send you some (very) hot weather we have down her
e
(for me, a way too much). Temperatures have been reaching 35 to 38 degree
s
Centigrades and we are not yet on high summer!
Regards
Jos
the results.
e
s
Regards
Jos
Man, could we use some of that weather up here right now, been about a we
ek
hovering close to -20C and more forecast for next week, the normal low is
something like -11 & high -2, that woud feel tropical right now. It is s
o cold
that my basement workshop (heated!) is about 12 or 14 and I want to work
on the
porject.
You remember of course that your Pro-Seal will cure significantly faster
at
your temperature? Do you have the option to buy some longer cure materia
l? We
used 2 hour for an ambient of around 25 and it worked out fine.
Gozzi wrote:
ek
o cold
on the
porject.
at
l? We
Gozzi wrote:
owThanks for the support Dave
erthe results.
eee
s
Regards
Jos
