zinchromate
zinchromate
Post by Bob Patterson » Sat Feb 18, 2012 8:52 am
Hi Gilles !
If you brush on Polyfiber Epoxy Primer, and assemble the
mating surfaces while still wet, you should be fine ! (and dip
the rivets in PEP before inserting & pulling ...)
There are several products you can use to mist the big
inside surfaces - Boeing D-29, and Northern Shield are a couple
that some have used .... both go in after completing construction,
and one treatment is good for many years.
---------------------------------orig.-----------------------------
At 10:22 PM 1/11/04 -0400, you wrote:
we are now starting to construct the wings of our Elite . So far we have
primed everything with zinchromate. Remember that we are going to fly
floats (no salt). from your experience would you keep priming everything..
Quite a few guys tell me to prime just the mating surfaces and then oil the
intrior generously with Denitrol, which is good for about 30 years.
Would appreciate to have some comment on that
Thanks gang
gilles 717e
The new MSN 8: advanced junk mail protection and 2 months FREE*
http://join.msn.com/?page=dept/bcomm&pg ... %2fjoin.ms
n.com%2f%3fpage%3dmisc%2fspecialoffers%26pgmarket%3den-ca
Gilles St-Pierre
zinchromate
Post by Gilles St-Pierre » Sat Feb 18, 2012 8:52 am
Thanks gang
gilles 717e
http://join.msn.com/?page=dept/bcomm&pg ... et%3den-ca
