Jeffrey,
You wrote "I also plan to install angles (3/4 x 3/4 x/
1/8) under the floor from firewall to carrythough near the engine mount
brackets".
I got this idea from Murray Cherkas - to use sections of witches hat riveted
fore/aft along the external side of the floor panel to stiffen it. I think it
is more aesthetically pleasing, but probably more expensive, than using angle.
I posted a couple of photos to the archives under Rebel-Fuselage.
Just thought I would throw the idea out to you as an option & information.
Roger Hoffman #687R
Eugene, OR USA!
Rebel Floor Stiffener (was Engine Mount Torque Values)
rognal
Dave,
The source is Murphy Aircraft. Rebel Part #FUS-12. These are the same witches
hat sections that are supplied for the firewall stiffener on the Rebel. I
don't have my purchase receipts here at home, but I think Murphy charged me
approx $30 (a guess) for enough to make the floor stiffeners.
Aircraft Spruce sells something similiar. Their "hat section aluminum
stringers" appear dimensionally smaller and appear to have a rolled flange
rather than a flat flange.
Hope this helps.
Roger Hoffman #687R
Eugene, OR USA!
Hope this helps.
Roger Hoffman #687R
Eugene, OR USA!
David Stroud
Roger..could you please state a source of those witches hat stiffeners? Thanks.
Dave Stroud, Ottawa, Canada
Christavia Mk 1 C-FDWS
Fairchild 51, early construction
Sent: Tuesday, December 30, 2003 10:20 AM
Subject: Rebel Floor Stiffener (was Engine Mount Torque Values)
Jeffrey,
brackets".
Roger Hoffman #687R
Eugene, OR USA!
Dave, these are about 3" wide with a 3/4" flange each side and then the rest
bent exactly what the description implies....bent to look like a pointed
witches hat if viewed from an end. Not the Wing stringer material you were
looking for on RAA national. If you are looking for this witches hat
material, as well as your wing stringer material, I have a few 6' lengths of
something bent fairly similar (in 2024T3) that is used on Pipers.
Sent: Tuesday, December 30, 2003 12:39 PM
Subject: Re: Rebel Floor Stiffener (was Engine Mount Torque Values)
Thanks.Roger..could you please state a source of those witches hat stiffeners?
rivetedDave Stroud, Ottawa, Canada
Jeffrey,
brackets".
think itfore/aft along the external side of the floor panel to stiffen it. I
angle.is more aesthetically pleasing, but probably more expensive, than using
information.I posted a couple of photos to the archives under Rebel-Fuselage.
*-------------------------------------------------------------------------*Roger Hoffman #687R
Eugene, OR USA!
