Metal Thickness
Gary
Metal Thickness
Post by Gary » Sat Feb 18, 2012 12:07 am
I wonder if someone could tell me the thickness of the 6061 used for the
trail edge of the flaps/ailerons. When I measure with the venire I read
0.040" . The reason for asking is that I made a mistake and have three
pairs of holes to close together. I had order three new main aileron
ribs (AIL-23, @ $21 per rib) and asked about the trailing edge. The
person filling the order said it would cost a good deal more then the
price of the rib. I can then get the material and try bending it.
Gary
712R
Lonnie Benson
Metal Thickness
Post by Lonnie Benson » Sat Feb 18, 2012 12:07 am
Gary,
Have you checked out the trailing edge material sold by Aircraft Spruce?
$11.65 for a 12 foot length.
Sent: Friday, December 19, 2003 2:36 AM
Subject: Metal Thickness
Gary
712R
klehman
Metal Thickness
Post by klehman » Sat Feb 18, 2012 12:07 am
Gary
Sorry I can't answer this for you as mine are covered but I did not
think they were that thick. If they are then it is not real easy to put
a nice radiused bend in a 6 foot long piece of metal. Most brakes won't
do a bend that tight and the metal springs back somewhat after you bend
it as well. I've made a lot of replacement parts but I'd price this part
from MAM (including shipping) before deciding what to do. It is
satisfying to know that an error has been properly corrected. Sounds
like you've ruled out the possibility of rivetting a doubler inside the
piece that you have to either cover the problem holes, or to make your
existing part a bit longer on the far end from the control horn?
Gary
712R
LisaFly99
Metal Thickness
Post by LisaFly99 » Sat Feb 18, 2012 12:07 am
In a message dated 12/21/03 5:54:01 PM Central Standard Time,
srwhitenect@hotmail.com writes:
Just went out and measured a left over piece. It's .016"
Just did the same on kit 281R and it's 016.
Phil&Lisa Smith
#460R
N414D
steve whitenect
Metal Thickness
Post by steve whitenect » Sat Feb 18, 2012 12:07 am
Steve W.
Subject: Re: Metal Thickness
Date: Sat, 20 Dec 2003 12:14:15 -0500
Gary
Gary
712R
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=dept/bcomm&pg ... et%3den-ca
