WESTACH FUEL PROBES MOUNTING
Jims170A
Post by Jims170A » Sat Feb 18, 2012 12:04 am
Hi Mike
I used a 24 inch long probes with the first 5 inches bendable. Mounted on
the forward top of the root rib and went Diagonal to the outboard low spot of
the tank. This was done to help with the fuel gauges readings ; on the ground
3 point compared to level flight.
Westach will sell direct, ask for there aviation catalog. 707-938-2121
Sonoma CA
Jim R254
Jims170A@cs.com
hi all
can any one who has used westach fuel probes suggest hOw to mount the probes
diagonal across the tank, at root, following main spar ?
mike #007
Jones, Michael
Post by Jones, Michael » Sat Feb 18, 2012 12:04 am
HI JIM
got the probes already just trying to figure out best mounting menthod and
set up, thanks
Sent: Friday, November 28, 2003 1:29 PM
Subject: Re: WESTACH FUEL PROBES MOUNTING
Hi Mike
ground
Sonoma CA
Jim R254
Jims170A@cs.com
hi all
probes
mike #007
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 12:04 am
Hi Jim,
How is the Rebel coming? I haven't heard from you for a while.
Bruce
