Hi guy's I'm looking for info on 0-360 motor mount. I have talked to Murphy people,eg.Brian, Robin, about the flex in mount about 1/2",two AME I know they beleive that there should be no flex in the mount eg. bottom legs,and rubber mount. Is there any body out there that has some info. I bought FWF kit for Elite for my Rebel. THANKS jerry
engine mount 0-360
engine mount 0-360
I don't know how your detecting the flex in your motor mount. If your seeing
movement at the spinner or you can notice vibration when running the engine.
I would be suspect of the prop being out of balance. Unless you have a
friend with a dynamic balance setup go see your local prop shop. If the prop
was not dynamic balanced, you will be happy with the result.
Al
Moose, N526AP
Cc: "jerry purdom" <jerrygoneflying@shaw.ca>
Sent: Wednesday, November 26, 2003 6:08 PM
Subject: engine mount 0-360
Al
Moose, N526AP
Murphy people,eg.Brian, Robin, about the flex in mount about 1/2",two AME IHi guy's I'm looking for info on 0-360 motor mount. I have talked to
engine mount 0-360
Hi Al: I can see the flex when one person pushes up and down on spinner and
then you can see bottom legs of mount flex and rubber mounts move. I have
torque motor mount bolts down, Wayne says his mount flexes and that it
should move,the prop seems to be fine,its a Warp drive 4-blade climb (square
tip) prop.THANKS jerry
Sent: Wednesday, November 26, 2003 7:57 PM
Subject: Re: engine mount 0-360
seeingI don't know how your detecting the flex in your motor mount. If your
engine.movement at the spinner or you can notice vibration when running the
propI would be suspect of the prop being out of balance. Unless you have a
Iwas not dynamic balanced, you will be happy with the result.
Al
Moose, N526AP
Murphy people,eg.Brian, Robin, about the flex in mount about 1/2",two AMEHi guy's I'm looking for info on 0-360 motor mount. I have talked to
*-------------------------------------------------------------------------*know they beleive that there should be no flex in the mount eg. bottom
